RevitGary Posted March 18, 2010 Share Posted March 18, 2010 (edited) I am trying to cut through a wire display The 6mm wires I have created look fine until I cut a section through them. Then they become diamond shapes instead of circular. Need some quick help on this one ... any ideas? I think it is some kind of section resolution problem. The circle is displaying faceted. If i could some how increase the faceting for a smooth section circle thats what i am looking for I just dont know the setting. Edited March 18, 2010 by RevitGary Link to comment Share on other sites More sharing options...
olaojo1 Posted March 23, 2010 Share Posted March 23, 2010 it might not be the resolution.it might be the way the family was configured to display in section.Go to edit family and check out the section configuration if its circular. Link to comment Share on other sites More sharing options...
RevitGary Posted March 23, 2010 Author Share Posted March 23, 2010 What do you mean by section configuration? The part was made with a swept circle. It is only .188" in diameter Link to comment Share on other sites More sharing options...
kris McIsaac Posted March 24, 2010 Share Posted March 24, 2010 I don't an answer for you sorry, but it seems that round extrusions display ok but sweeps and revolved objects display with straight edges. This only happens in section and elevation. all ok in plan It also appears to only happen to external families not in place ones. I tried detail level and scale changes but it did not make any difference. sorry I could not be more help. I have spent the last couple of weeks creating a bunch of commercial kitchen families and now I realise many have this problem. Didn't even notice till now. Link to comment Share on other sites More sharing options...
RevitGary Posted March 24, 2010 Author Share Posted March 24, 2010 I tried making these several different ways. Including families and in place families. Extruded and swept they all have this problem in cross sections. In elevations everything is fine. Having thought about it just now I think I might know the solution. Create a family and when it is looked at in section have the section view hide the geometry and have it display detail lines in bedded in the family. This would be similar to in bedding detail line work in a section of a sliding door or window, except you would hide all modeled elements. I am pretty sure this is the way to make it work. I dont have the time to test it right now. If anyone can verify this please let me know. Thanks Link to comment Share on other sites More sharing options...
RevitGary Posted March 29, 2010 Author Share Posted March 29, 2010 In case anyone is still following this. I made a masking region in the family and it blocks out the geometry in the section and shows the masking region. Link to comment Share on other sites More sharing options...
