Flyby Animation
raziel
Hi guys, im starting a new project that is basically a flyby animation over some islands. Since the sky and sea are going to play a big part in this, im trying to get them to look as realistic as possible.
For the sea, im using a tesselated mesh with a noise modifier (animated) and the arch&design water material. For the clouds ive tried the mrSky with cloud images in the haze slot. Ive also tried the dust devil plugin to make the clouds, but max 2010 says its not supported, so what other way is there to make realistic clouds?
Thanks in advance!
I'd say if your up to it, you should give EON OZONE 4 a try. It creates any possible kind of clouds and they're realistic (I mean, really life-like). Most amazing atmosferic generatic software I've ever come across and has lots of presets to choose and start from. Hopt it helps.
Good luck.
