ivanjay Posted March 27, 2010 Share Posted March 27, 2010 I followed a wonderful tutorial on cgarchitect which walks through creating a ceiling grid with 2 x 2 recessed lights built into the material. Traditionally, I was modeling all of this so this sames considerable time as all of my renders are interiors and most with a ceiling grid. However, I get the notice that there are no photon emitters in the scene. Is there a way to make the A & D emit photons. If not, is it as simple as just placing a light just below or....? I rely on photons/GI to give me the great shadowing and depth. I had read you can just crank up the final gather but my assumption is that will not produce the same quality renderings, what is your experience? Link to comment Share on other sites More sharing options...
pixelperfectg Posted March 27, 2010 Share Posted March 27, 2010 Is there a way to make the A & D emit photons.Unfortunately, no. If not, is it as simple as just placing a light just belowYes. Link to comment Share on other sites More sharing options...
ivanjay Posted March 27, 2010 Author Share Posted March 27, 2010 Unfortunately, no. Yes. I did try that and it looks great. My next question is am I "doubling" the light to make this physically incorrect or should I not worry about that? My thought is the self illumination throws off light as well as the physical light so this is truly accurate? Link to comment Share on other sites More sharing options...
pixelperfectg Posted March 27, 2010 Share Posted March 27, 2010 I did try that and it looks great. My next question is am I "doubling" the light Yes, both are creating light but it's not a 1:1 doubling effect of the light because a mental ray self-illuminated material isn't as accurate as an actual photometric light source. I believe it even mentions this in the help file in one of the discussions about FG or self-illuminated A&D materials but I don't remember which off the top of my head. If you use an actual light source below the self illuminated plane then you can simply disable the "Illuminates the Scene (when using FG)" option on the self-illuminated A&D material if the combination is putting out too much light for you but I'd still leave it self-illuminated to represent the visible light source. Link to comment Share on other sites More sharing options...
ivanjay Posted March 27, 2010 Author Share Posted March 27, 2010 Yes, both are creating light but it's not a 1:1 doubling effect of the light because a mental ray self-illuminated material isn't as accurate as an actual photometric light source. I believe it even mentions this in the help file in one of the discussions about FG or self-illuminated A&D materials but I don't remember which off the top of my head. If you use an actual light source below the self illuminated plane then you can simply disable the "Illuminates the Scene (when using FG)" option on the self-illuminated A&D material if the combination is putting out too much light for you but I'd still leave it self-illuminated to represent the visible light source. That makes sense. Thanks for your help! Link to comment Share on other sites More sharing options...
