Koper Posted March 30, 2010 Share Posted March 30, 2010 I don't seem to be able to do this:mad: I set it when I save the file output value but it keeps on rendering 32bit I have now even tried to over write it in max script with the exrio function but with no luck. even if I save it by hand it saves as 32bit Have anyone also noticed this and maybe have a solution? pls help Link to comment Share on other sites More sharing options...
Stephen Thomas Posted March 30, 2010 Share Posted March 30, 2010 16-bit or half-float EXRs are still 32-bit files. As far as I know it is just the precision that differs i.e. the half-float version has the same unlimited range as the full-float version but uses integers rather than decimal places. I guess the name is something of a misnomer. Link to comment Share on other sites More sharing options...
Koper Posted March 30, 2010 Author Share Posted March 30, 2010 interesting but the file sizes should change right? gonna make another quick test thanx for the reply Link to comment Share on other sites More sharing options...
Stephen Thomas Posted March 30, 2010 Share Posted March 30, 2010 The file size should be less as technically it's not having to store as much data. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted March 30, 2010 Share Posted March 30, 2010 Koper, Are you rendering through Backburner, or saving local? I had a problem where it would save as 16bit if I saved local, but 32bit if I went through backburner. I solved the problem by changing the default bit value for EXR's on all of the farm machines. http://forums.cgarchitect.com/39019-exr-16bit-compression-through-backburner.html#post270961 Also, in production my 16bit EXR's are typically running 30-40%of the size of 16bit TIFF files. Though I do not currently store extra channels in my EXR's. The file size savings has the potential of being even greater... http://forums.cgarchitect.com/38819-what-best-format-save-render.html#post269619 . Link to comment Share on other sites More sharing options...
Koper Posted March 30, 2010 Author Share Posted March 30, 2010 Im going through backburner with a script. I have searched the forum for this information but didn't find it. These are 2 excellent excellent posts, thanx Travis I'll probably change all the ini's of all the computers in the queue. Much'O'preciated!! Link to comment Share on other sites More sharing options...
Koper Posted March 30, 2010 Author Share Posted March 30, 2010 bada bing bada BOOM Thanx Travis, this also solves our problem we had with exr's being different sizes rendered on different computers. Its a huge difference in filesize and in what im rendering, only 1mb bigger than a tga version. I think you should make a new stickey thread on this topic as you had a solid answer cool A Link to comment Share on other sites More sharing options...
