MulinoBianco Posted April 1, 2010 Share Posted April 1, 2010 hi there evry time when i work some model in 3ds max my polygons disappear and i don't know why somethimes is very difficult to work.I am using 3ds max 2009 64 bit and I had same problem at previously pc.I am also sending you a foto to see the problem Link to comment Share on other sites More sharing options...
Thablanch Posted April 1, 2010 Share Posted April 1, 2010 F2 - toggle between full red selection and contour selection. Could it be that you hit it in your workflow when using F3, shaded view? Click F2 again and the selected poly will turn to full red again. Link to comment Share on other sites More sharing options...
1d2d3d4d Posted April 1, 2010 Share Posted April 1, 2010 or maybe the normals are reversed...add the 'normal' modifier or i think its 'flip faces' in sub object menu... Link to comment Share on other sites More sharing options...
MulinoBianco Posted April 1, 2010 Author Share Posted April 1, 2010 thanks a lot it was f2 cheers! Link to comment Share on other sites More sharing options...
