erspek Posted April 1, 2010 Share Posted April 1, 2010 I see the circular lines at the object and shadows when I render at big size. (6000x4000). How can I solve this problem? If I use Mitchell-Netravali antialiasing filter with 1,333 blur then this circular lines are decreasing (or little bit disappearing). But I don't know it's true. Here is the vray options: Image Sampler - Adaptive DMC - Antialiasing filter Area Size: 1,5 Adaptive DMC image Sampler - min subdivs=1 - max subdivs=4 - Crl tresh=0,001 Environtment - GI Environment (on) Color mapping - default settings (no change) Indirect illumination (on) - Primary Bounces Irradiance map - Secondary Bounces Brute Force Irradiance map - Current preset Medium - Hsph. Subdivs=100 - Interp. samples=40 Brute Force - Subsdivs=100 - Secondary Bounces=5 V-ray DMC Sampler - Adaptive Amount=0,85 - Noise treshold=0,001 - Min Samples=8 Thank you, Ersin Link to comment Share on other sites More sharing options...
