How can I create glass that gradients from clear to frosted?
danb4026
Sure. Plug a Gradient map into the Refraction Glossiness slot. If you want your reflection glossiness to follow the same pattern, plug the same map into the reflection glossiness slot too.
You can modulate the "abruptness" of the transition and the degree of "frostiness" by tweaking the RGB curve in the output section of the Gradient map.
