RevitGary Posted April 2, 2010 Share Posted April 2, 2010 (edited) My first Kitchen. My design and colors. Was going for something unique. Comments / Crits appreciated, especially technically. Edited April 2, 2010 by RevitGary Link to comment Share on other sites More sharing options...
Jonathan Sanchez Posted April 2, 2010 Share Posted April 2, 2010 Hey Gary Looking good so far.. render quality is kinda low which makes it difficult to judge detail. Are you using any GI? Link to comment Share on other sites More sharing options...
RevitGary Posted April 2, 2010 Author Share Posted April 2, 2010 Yes FG and GI defaults in max 2010 with Mental ray Link to comment Share on other sites More sharing options...
Jonathan Sanchez Posted April 3, 2010 Share Posted April 3, 2010 ok.. thing standing out most for me is the countertops which I'm assuming are granite right? It's textures..first, the granite should have glossy reflections. It's colors a bit to bright too, I'd make it a little darker and richer.. more realistic. Link to comment Share on other sites More sharing options...
RevitGary Posted April 3, 2010 Author Share Posted April 3, 2010 No they are not granite. They are meant to be oxidized metal. I think a slight reflection might will help. I will add one thanks!! I am happy with the color. I do need to adjust the maps so they do not repeat. Link to comment Share on other sites More sharing options...
abmitalia Posted April 4, 2010 Share Posted April 4, 2010 Gary - Whatever all materials in your scene ''supposed'' to be ... define them better. RK Link to comment Share on other sites More sharing options...
RevitGary Posted April 4, 2010 Author Share Posted April 4, 2010 abmitalia said: Gary - Whatever all materials in your scene ''supposed'' to be ... define them better. RK What do you mean? Link to comment Share on other sites More sharing options...
abmitalia Posted April 4, 2010 Share Posted April 4, 2010 happy eastern first -----Sorry didn't express me well - ... for example the oxidized metal seams to have a too small sized map on it and looked washed out , its not repetitive but something lacks to make it define as oxidized metal. The vase of the flower if it is '' glas '' is way too reflective , the material of the oven is way to opaco ... well a little bit all over. The design idea itselfe is great and a like it a lot. Link to comment Share on other sites More sharing options...
3dterior Posted April 4, 2010 Share Posted April 4, 2010 You should reduce "noise" from your image. Link to comment Share on other sites More sharing options...
RevitGary Posted April 4, 2010 Author Share Posted April 4, 2010 3dterior said: You should reduce "noise" from your image. OK... what do you mean? Link to comment Share on other sites More sharing options...
Stan Zaslavsky Posted April 5, 2010 Share Posted April 5, 2010 good start i think .. adding some more lights would help bring up brightness - it seems a little dark for a kitchen .. have you got mr portals in the windows? another trick you could use would be to add a mr portal light behind the camera and light up whats in front of the view .. but the dark outlook also seems to be the effect of the dark chocolate walls another question is it looks like you have three under bench ovens and your floor tiles are quite large so overall the sense of proportion is a bit lost hope the above helps Link to comment Share on other sites More sharing options...
RevitGary Posted April 6, 2010 Author Share Posted April 6, 2010 (edited) Outside tweaked, brightened overall image. more contrast on metal counters. Better oven window and glass vase. There are only two ovens the stove top will have warm drawers underneath . The floor is meant to be large squares. made window frames brown to match wall. Edited April 6, 2010 by RevitGary Link to comment Share on other sites More sharing options...
braddewald Posted April 6, 2010 Share Posted April 6, 2010 (edited) The best advice I can give you is: reference images, reference images, reference images!! Find something that looks like what you are going for, then try to match the materials as best you can. My family has been in the kitchen business for years and years now, so I may be a little too judgemental here. So, I'll leave it at these couple suggestions: Oxidized metal should have a clear coat on top of it, which would give it a shiny appearance. (otherwise the metal keeps oxidizing). Also, the ovens look a little big. Look up some specs for ovens to get an idea of their size. Edited April 6, 2010 by braddewald Link to comment Share on other sites More sharing options...
