AutoCAD to PhotoShop
STRAT
I can not see to find my pdf printer in the ACAD2000 printer setup. You mentioned you need Adobe distiller for this? By the way - the uncompressed TIFF printer comes out horrible. The eps>illustrator>tiff>photoshop route is cleaner. ON another note...I have a friend here at school who swears by Corel Draw. Functions much the same as Illustrator in that it will open an eps or dwg file and keep it in vector format (photoshop rasterizes). With corel you can snap to vertexes to do plan shading or whatever.
[ May 03, 2003, 09:34 AM: Message edited by: xgarcia ]
yeah, you need Adobe Acrobat (not reader) installed on your machine. This creates two printer types, PDF Writer and Distiller.
This is by far the best way to get line drawings into photoshop as it only rasterises on import into photoshop, and it asks at what dpi you'd like it rasterised at...very easy and very clean.
This was brought in using .pdf, and at full resolution (saved small for web here) the linework when printed comes out as clean and sharp as if printed straight from acad.
  • 2 weeks later...
Same thing happens when you plot to EPS file and open in photoshop...about the same quality I think. I keep hearing wonders about Corel-Draw working with eps files. Check it out.
Originally posted by STRAT:
Kaos - you can do that but you get the same problem as described in the above mentioned thread - the resolution is crap because you cant control the dpi, no matter how big the pixel size may be.
Just use illustrator. Export from autocad as eps. open it in illustrator, and export to photoshop. You can set your dpi too!
Guest Rigged
This is the way i do it:
I've added a virtual Postscript plotter to Autocad; added with the add plotter wizzard.
Adobe > postscript 2 plotter
Now I can create a plotfile in .eps format > pot to file with the new virual postscript polter.
This format is a vector graphic format, witch meens resolution indipendent. I can load it in Photoshop and define its resolution later. :) 1200 Dpi or such.
  • 8 months later...
My way to do this is through PDF's. It works like a normal printer so the pen-widths are the same. If you don't have Acrobat Writer, then you could download dialux since that comes with a free PDF printer. And the nice thing is: its resolution independant just like .eps
I do regognize the problems above with eps. I never could get nice results with it..
Max out your view resolution in Acad before you create the EPS file then it shouldn't look like a "low poly" segmented pline when you view it in Photoshop. If however this still doesn't work, there is a trick I use in Photoshop where I select the outer boundries of the imported EPS layer, Smooth my selection by 1 or 2 pixels and then re-stroke the selection on a new layer.
  • 8 months later...
It´s simple save the drawing normally (*.dwg).
import it in Coreldraw ( vectorial format). Export only selected to a bitmap format such as tiff.
Other way is: Select your drawing in Autocad and paste it into corel as binary exchange format. Explode it and select all the lines and delete the rest.
Change the color of the lines to your chosen color.
Hope this helps.
Pepe
  • 3 months later...
  • 1 month later...
I know this is an ancient thread, but there has always been a Plotter that you can add to AutoCAD, it outputs images at any pixel ratio upto 8000x8000 pixels. All you do in Photoshop is define the aspect for dpi.
In Autocad, Options, Plotting, Add Plotters, My Computer, Raster File Formats.
Pick one and then add a Custom Paper Size. Options are galore, so go through them as needed. This has been available since around AutoCAD 11. I use it on every version I encounter although I don't know if they took it out of 2004/2005 since we haven't loaded those at work. We'll move to 2006 when that comes in.
Maneswar
  • 3 weeks later...
Don't know who started this,
I haven't seen all of this thread so I hope this fits.
Do you not have a jgp plotter in ACAD? I just plot to jpg, setting the resolution (no of pixels x no of pixels) in the custom paper size.
Techy in our office says the jpg plotter is just part of the normal plotters given with ACAD.
Note that if you increase the resolution, more x more pixels, the resultant image has more detail, is smoother, finer, when you zoom in but is pretty light to view if for example you are using the image for a Powerpoint presentation. I have found the coarser image better for things like that because it holds some weight when you are not zooming in.
Alternatively - use pdf's as I see people have said. I have only just started using photoshop so will give it a go myself. I know pdf's are good for keeping hold of lineweights etc.
Best of luck.
Andy
  • 1 month later...
