Sketchrender Posted April 4, 2010 Share Posted April 4, 2010 Just a quick question. The colour grading technique that Alex Roman uses on his images. How is the done through photoshop, or is it a known process for film use only. I know he uses After effects, but for still images ? Thnak you phil Link to comment Share on other sites More sharing options...
AJLynn Posted April 4, 2010 Share Posted April 4, 2010 Cheat with Color Efex Pro Link to comment Share on other sites More sharing options...
BBB3 Posted April 4, 2010 Share Posted April 4, 2010 He uses AE both for animations and for stills. AFAIK, he uses Magic Bullet Looks for AE. The plugin has now been published for Photoshop too. It's called Magic Bullet Photolooks but it's identical in all respects. It's also pretty cheap for what it does. A big advantage over other PShop plugins is that it can process 32bit images, which virtually no plugin, including PShop's built-in tools, can do. If you do your post in PShop, buying this plugin is pretty much a no-brainer. Link to comment Share on other sites More sharing options...
