Josh1587140445 Posted June 13, 2002 Share Posted June 13, 2002 I have been doing some renderings with alot of civil work to them with VIZ 4. And some of these sites have alot of change in the topography. But I need to add roads that follow the topography. I just can't seem to get my road profile to merge with the terrian created. Any suggestions on how this can be accomplished Link to comment Share on other sites More sharing options...
samp Posted June 13, 2002 Share Posted June 13, 2002 Euh ... Maybe you could copy the terrain. Make a spline that has the form of your routenet. And cut that form out of your terraincopy with "compound objects - shapemerge" Link to comment Share on other sites More sharing options...
quizzy Posted June 13, 2002 Share Posted June 13, 2002 If you dont like mesh (patch) modelling go here and download the glue tool.... For all software from itoosoft click here [ June 13, 2002, 09:16 AM: Message edited by: quizzy ] Link to comment Share on other sites More sharing options...
samp Posted June 13, 2002 Share Posted June 13, 2002 Quote Originally posted by quizzy: If you dont like mesh (patch) modelling go here and download the glue tool.... For all software from itoosoft click hereLooks the same as shapemerge to me ... Or are there more possibilities ? Link to comment Share on other sites More sharing options...
quizzy Posted June 14, 2002 Share Posted June 14, 2002 its more like a shape projector on a surface, with shapemerge you don't get a shape. Link to comment Share on other sites More sharing options...
Wolf Posted June 14, 2002 Share Posted June 14, 2002 If you are serious about it, you need to get world construction kit it has special tools that do just that. go here... http://www.3dnature.com/ Link to comment Share on other sites More sharing options...
Jefferson Grigsby Posted May 26, 2003 Share Posted May 26, 2003 The easy "sledhammer Approach" would be to draw the bounding shape of the road, extrude it, Boolean subtract it from the terrain mesh (suggest you collapse both before doing this). Take copies of both and do the same with an itersection Boolean for the actual road surface. Hope that helped some. Link to comment Share on other sites More sharing options...
Da_RoCk Posted May 31, 2003 Share Posted May 31, 2003 Hi peeps. I think that the glue tool really works. It seems that it will align your road in respect to plan directly to the terrain. but if ur planning to apply cut and fill with your road alignment, better make the model first... Link to comment Share on other sites More sharing options...
Allen Bussell Posted June 2, 2003 Share Posted June 2, 2003 If you're using AutoCAD 2000 or 2002 - EasySite is a great program for vizualizing Civil work - simple and quick. www.cadeasy.com Hope this helps. Link to comment Share on other sites More sharing options...
seismograph Posted June 3, 2003 Share Posted June 3, 2003 www.pracsys.hu few years ago i watched a presentation of thier archisite software, which seamless was integrated to archicad. Everything was semiautomated. Drawing points with a height..archisite created the terrain; drawing a spline over this terrain ..and archisite draw the streets and slopes!! so easy!! Link to comment Share on other sites More sharing options...
Richard McCarthy Posted June 24, 2003 Share Posted June 24, 2003 or You could use Revit... Integrated Site modeler that's super easy to use. Import your 3D terrain data from AutoCAD, Press a button, BAM! instant 3D terrain It also let you grade the site, and also put in all sorts of goodies (parking space, trees, lights, etc) into it with full intelligence of standing up right and above the terrain. -RM Link to comment Share on other sites More sharing options...
STRAT Posted August 20, 2003 Share Posted August 20, 2003 do it the most effective easiest way there is - SHAPE MERGE Link to comment Share on other sites More sharing options...
kunstraum.tv Posted August 20, 2003 Share Posted August 20, 2003 glue tool...free plugin for max/viz http://www.itoosoft.com/english/freeplugins.html Link to comment Share on other sites More sharing options...
quizzy Posted August 21, 2003 Share Posted August 21, 2003 wow, this topic is going in circles... Link to comment Share on other sites More sharing options...
nisus Posted October 6, 2003 Share Posted October 6, 2003 definately... probably because it's way old! Link to comment Share on other sites More sharing options...
pidge Posted December 1, 2003 Share Posted December 1, 2003 I agree that the glue tool from itoosoftware works the best but remember when you create your line turn up the interupation to about 22,but the one thing that i found was that the glue tool doesn't let you align your road maps after you apply it,not like the lofting tool,this is a problem i always get,if someone knows how it fix this prob life would be so much easier for me. Link to comment Share on other sites More sharing options...
Wendelld Posted December 3, 2003 Share Posted December 3, 2003 Try this amazing Autocad plugin called EasySite from CadEasy, here's the link http://www.cadeasy.com/software_information.asp?detail_id=44. The plugin is a 15 full version-15 day trial. This will make your life easier. Link to comment Share on other sites More sharing options...
Troy Posted June 29, 2004 Share Posted June 29, 2004 Easy Site is pretty good. Lately i've just been doing it all in Max with teh terrain tool and shapemerging splines. Lofting can be very powerful for making roads, curbs, and sidewalks all at once with the mat IDs assigned at the spline level. Link to comment Share on other sites More sharing options...
