postite Posted April 8, 2010 Share Posted April 8, 2010 Hi. I want to use a simple maxscript because I import a lot of *.obj and I need to clean them. I used maxscript Listener because it usually works like a charm and I'm not a maxscript guru I want to: 1-Transform to poly edit 2-Be in poly 3-Select all poly 4-Clear all smoothing groups 5-Deselect all poly 6-Hide selection Here is what I have: macroScript Clean-obj category:"DragAndDrop" toolTip:"Clean Obj" ( macros.run "Modifier Stack" "Convert_to_Poly" subobjectLevel = 4 actionMan.executeAction 0 "40021" $.EditablePoly.SetSelection #Face #{1..988} $.EditablePoly.autosmooth () $.EditablePoly.setSmoothingGroups 0 subobjectLevel = 0 actionMan.executeAction 0 "223" hide $ ) But I get an error message... I would also like to apply a random color before hiding the object. If somebody could help me ? Thx Link to comment Share on other sites More sharing options...
DanGrover Posted April 8, 2010 Share Posted April 8, 2010 Hello mate I see when you're selecting the faces, does that not assume that the object has between 0-998 faces? I don't know if that's always the most faces you'll have, but the line... polyop.setFaceSelection $ #all will give you ALL the faces. Infact, this way, you also don't need to be in sub-object mode I believe, so you could probably delete some other lines but maybe it'd be best not to mess around with it! With regards to the error, it suggests that it needs 3 arguments, whereas you've given it 1 ("3"). What might be easier is, instead of clearing them (which seems surprisingly tricky to do in maxscript), just assigning the auto-smooth an amount of 0 and then autosmoothing it. For the colour, it's as simple as adding: $.wirecolor = [(random 0 255),(random 0 255),(random 0 255)] Anywhere in there. Link to comment Share on other sites More sharing options...
