wannabeartist Posted April 11, 2010 Share Posted April 11, 2010 Hi all, I'm working on a scene that would really benefit from a fire effect - in a fire place. I've been searching for quite a while now but just about all tutorials I can find require FumeFX or some other expensive plug-in. I was surprised that there's not any more material on the subject or Max dynamics in general. Is there a way to make realistic looking fire with just plain Max, without plug-ins? With particle flow or something else? Thanks! Link to comment Share on other sites More sharing options...
braddewald Posted April 11, 2010 Share Posted April 11, 2010 I was just faced with this problem for my image here. What I did was use a few intersecting planes with a vraylightmaterial. The vraylightmaterial has a fire bitmap for the diffuse and its alpha channel in the transparency slot. Then some photoshop to clean it up in post. Link to comment Share on other sites More sharing options...
wannabeartist Posted April 11, 2010 Author Share Posted April 11, 2010 Thanks, That's definitely an option to consider. I was kind of hoping to use a particle system for this, but that might just be waste of time - my client is expecting a simple still image anyway. I love your fire place by the way, looks awesome! Link to comment Share on other sites More sharing options...
braddewald Posted April 11, 2010 Share Posted April 11, 2010 Thanks! Link to comment Share on other sites More sharing options...
Tommy L Posted April 11, 2010 Share Posted April 11, 2010 Do it in post. Create some kind of pass that carries tracking points then buy a fire animation from istock or something similar, one that carries an alpha channel. I just had to do an animation of a character carrying a flaming torch. I used this technique with success. Didnt fancy tackling a particle effect etc. Link to comment Share on other sites More sharing options...
cupsster Posted April 11, 2010 Share Posted April 11, 2010 (edited) If it should be static picture then bitmap is quite good solution.. Try to search @evermotion free stuff.. I think there are some free fire textures for download.. >> fire flames fuego llamas Edited April 11, 2010 by cupsster link insert Link to comment Share on other sites More sharing options...
AJLynn Posted April 11, 2010 Share Posted April 11, 2010 Make some stick-shaped objects and apply a wood texture, then use Reactor and animate them rubbing together vigorously. Eventually it will start the fire for you. Make sure to uncheck "damp conditions" in the preferences. Link to comment Share on other sites More sharing options...
Nic H Posted April 12, 2010 Share Posted April 12, 2010 ^ this is what i was going to suggest. it will get the most natural results. if you cant get that going model up some matches, particle systems arent worth the time for fire. Link to comment Share on other sites More sharing options...
Tommy L Posted April 12, 2010 Share Posted April 12, 2010 The 'Lighter' plugin from zippo is pretty good for making fire. Link to comment Share on other sites More sharing options...
wannabeartist Posted April 12, 2010 Author Share Posted April 12, 2010 Thanks for the ingenious ideas! I think I go with the sticks. I should probably dry them first in a blazing hot sunny scene for a few frames before using them No, seriously though, the post work ideas are starting to sound more and more appealing. Link to comment Share on other sites More sharing options...
Tommy Burns Posted April 14, 2010 Share Posted April 14, 2010 Make some stick-shaped objects and apply a wood texture, then use Reactor and animate them rubbing together vigorously. Eventually it will start the fire for you. Make sure to uncheck "damp conditions" in the preferences. :D:D:D Very good!! Link to comment Share on other sites More sharing options...
