Dave Buckley Posted April 12, 2010 Share Posted April 12, 2010 i should know this but i don't. whenever i import geometry from sketchup, it's nice a clean, however one problem is that it's an edit mesh. if i add edit poly modifier or convert to editable poly, i get a lot of unwanted edges appear. how to i go from edit mesh to edit poly whilst maintaining cleanliness of the geometry? Link to comment Share on other sites More sharing options...
Koper Posted April 12, 2010 Share Posted April 12, 2010 don't think its possible, but you can use the quadrify all function in the ribbon of max 2010 to get rid of triangle faces Link to comment Share on other sites More sharing options...
Dave Buckley Posted April 12, 2010 Author Share Posted April 12, 2010 quadrify all doesn't seem to want to do it either, neither does the quadify modifier nor does the autoedges script. how disappointing, there must be people out there having this very same problem when working with sketchup files Link to comment Share on other sites More sharing options...
Thablanch Posted April 12, 2010 Share Posted April 12, 2010 (edited) There is a script by Pierre Felix Breton ( Autodesk) to remove edges from Revit models.. I guess this could help... http://www.pfbreton.com/2009/08/autoedges/ Edited April 12, 2010 by Thablanch Link to comment Share on other sites More sharing options...
alias_marks Posted April 12, 2010 Share Posted April 12, 2010 I guess one question that might help to know, is what are you trying to do with the sketchup models that edit mesh isn't sufficient for? i.e. why would you like to convert them to editpolys? Just more refined editing capibilities? Perhaps for beveling edges etc. easier? My workflow has usually been, if I need to edit an imported sketchup model beyond what sketchup brings into max, it's always been easier to hand model it... just my 2c Link to comment Share on other sites More sharing options...
Thablanch Posted April 12, 2010 Share Posted April 12, 2010 Or you can also go in the optimise modifier and use the button, if you only have a few pieces, and if the script is not working.. Link to comment Share on other sites More sharing options...
Nic H Posted April 13, 2010 Share Posted April 13, 2010 isnt it only a visual thing though? its just hidden edges isnt it? sketchup geometry is rubbish as soon as you do anything to it. remodel it. Link to comment Share on other sites More sharing options...
Dave Buckley Posted April 13, 2010 Author Share Posted April 13, 2010 I guess one question that might help to know, is what are you trying to do with the sketchup models that edit mesh isn't sufficient for? i.e. why would you like to convert them to editpolys? Just more refined editing capibilities? Perhaps for beveling edges etc. easier? My workflow has usually been, if I need to edit an imported sketchup model beyond what sketchup brings into max, it's always been easier to hand model it... just my 2c yes more refined editing capabilities, i only ever use editable mesh once i've finished modeling something to save memory as edit mesh is more memory efficient than editable poly i've already tried the autoedges from pierre, doesn't work i guess i just need to get used to edit mesh or re-model it until i find a better solution Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted April 13, 2010 Share Posted April 13, 2010 There's an autoedge in edit mesh. Edge mode. Select All. Auto edge. If it's not working, maybe it's because there are more than one edge in the same place. Does welding all the verts help?[/guess] Link to comment Share on other sites More sharing options...
