Terrain Modeling Help!
squid
Hi,
I am working on an aerial perspective of a 500+ acre site. I am hoping to use the same 3D model for the eye-level perspectives as well. There's three mild hills on this site (approx. +50 feet change in height.)
Here's what I've done so far:
1. I created the splines (at 10' increment) in AutoCAD
2. Import splines into VIZ4
3. Using imported splines, made a terrain object.
Everything appear ok at first, but after a closer look, I see facets around 'tight' turning contours (in areas where the creeks and roads are.)
Can anyone suggest a better technique?
Thanks,
Squid
Does anyone
  • 2 weeks later...
One good technique I like to use is to build your terrain splines at a higher resolution and apply the Normilize Spline modifier befor you turn it into a compound terrian object. The normalize spline modifier will keep the same shape of your spline but "normalize" your veticies at set incements. Example: if you set the increments to 6 inches you will then have a vertex on your spline every 6 inches. This will give you a better looking mesh and give you controll over your serface resolution without drasticly changing its shape. I highly recommend that you use this technique every time your working with a terrain.
Good luck! ;)
[ June 25, 2002, 05:19 PM: Message edited by: Erik Lund ]
hi everyone,
sorry that i have not been able to post further updates, but i have been working overtime on this presentation and was away meeting with the clients during the past several weeks.
since i was running out of time, i had to use the methods that i already knew to terrain object and shapemerge & glue to make roads, curbs, grass, etc. and about 10,000 rpc trees (but that's another story altogether...)
One good technique I like to use is to build your terrain splines at a higher resolution and apply the Normilize Spline modifier...
this sounds like great idea, i'll have to try it for the next iteration.
i will post a picture to illustrate the problem - can anyone suggest a url for storing images?
thanks,
squid
The Viz terrain modifier works off of the vertices of the splines, so just use the methods above to refine curves. For a 500 acre site, I would think RPC content would be serious overkill (and serious overhead). Have you looked at Forest Pro from Itoo? It might be a good altenative for you if you do a large site.
Hi,
Here are the images before the tweaks.
http://www.imgstudio.com/download.asp?src=0715200211340124.jpg
http://www.imgstudio.com/download.asp?src=0715200210500557.jpg
Memory overhead was surprisingly good (for 4000-5000 rpc tress) Final render (5100x2865) time was under 1 hour on a p42200 with 512ram
I did have memory problems with the RPC Spray Script. It seems that the file size doubles or triples after multiple RPC spraying of trees using RPC Spray Script - Not sure if it's a good remedy, but my solution was to save the viz file (with rpc trees) periodically, create new viz file, import old viz file with rpc trees, then save new viz file.
Big thanks for the 'normalized spline modifier', it reduced the poly count considerably!
Squid
Squid
  • 3 months later...
Being the WorldBuilder guy -- I'm going to go ahead and recommend WorldBuilder
http:\\http://www.digi-element.com
so -- why Worldbuilder?
1) Creates a dual scene with 3D Viz that shears cameras lighting, etc. and composites the joint render during render time, using everything's native renderer
2) Because of this you don't need to import or export -- just set up a joint render.
3) Imports DEM, gray scale height maps (which is easy from topo maps) and uses splines.
4) Render quality is excellent.
Okay -- so there is the WorldBuilder pitch.
Don
  • 2 years later...
I am not sure if this technique is applicible to what you are doing, but for my terrains in 3DsMax I like to start out with a plane divided up into as much detail as you wish starting first with low detail and then convert it to a mesh.
From there I use soft selection on the edit mesh modifier, select and drag points on the z plane. Points nearby are affected by the soft selection settings as to how much they follow the point or group of points you are dragging.
You may depending on your detail have a fairly rough mesh. At this point apply a mesh smooth modifier and for a little variation apply a noise modifier for a rocky terrain.
Render the top view and brush texture over it in photoshop and then apply it as a map to the model.
Right now I am creating a wonderful canyon with a waterfall soon to follow.
Hope this gives you some ideas. I have never worked with Viz before though.
  • 2 years later...
Personally I use VUE 6 infinite and Maya for Terrain modeling. I like the results I get along with Renderman.
Do you have any work you can show? I would be interested in using Vue on some projects...
EDIT: IF...I can get it to work.
Edited by Claudio Branch
  • 4 months later...
