cmrhm Posted April 15, 2010 Share Posted April 15, 2010 Hi, all I just finished a site plan rendering. Generally it is much better than I thought. But the grass pattern is really bothering. Since I modeled it in autocad, I wonder if this related to modeling issue? Or I need to revise the Vray settings? Suggestions pls. The weather in chicago is wonerful, it make me happy. I can try any suggestions. Link to comment Share on other sites More sharing options...
BrianKitts Posted April 15, 2010 Share Posted April 15, 2010 looks like a modeling issue. Try putting either a subdivide modifier on the object or a smooth modifier (or both) and see if it goes away. Link to comment Share on other sites More sharing options...
cmrhm Posted April 15, 2010 Author Share Posted April 15, 2010 looks like a modeling issue. Try putting either a subdivide modifier on the object or a smooth modifier (or both) and see if it goes away. Thanks. Never experienced this before. I modeled it in autocad 2007. It just some plines, then extruded. I will try to put those two modifiers in 3dmax to see what happened. Link to comment Share on other sites More sharing options...
acjwalker Posted April 15, 2010 Share Posted April 15, 2010 try just union the mesh in autocad and render it see if it makes a difference. Link to comment Share on other sites More sharing options...
Gus_Rayvus Posted April 15, 2010 Share Posted April 15, 2010 The square pattern makes me think it is a rendering issue. Are you distributing it? If so, it looks like a machine is dropping the maps. Link to comment Share on other sites More sharing options...
cmrhm Posted April 15, 2010 Author Share Posted April 15, 2010 try just union the mesh in autocad and render it see if it makes a difference. no, only one laptop. Link to comment Share on other sites More sharing options...
cmrhm Posted April 15, 2010 Author Share Posted April 15, 2010 (edited) try just union the mesh in autocad and render it see if it makes a difference. I am thinking just import pline into 3dmax then put extrude modifier there. that would be 3dmax objects, hope it solve the square pattern. It works after trying my ideas. Thanks folks. Edited April 15, 2010 by cmrhm Link to comment Share on other sites More sharing options...
