wannabeartist Posted April 17, 2010 Share Posted April 17, 2010 Hi, Has anyone tried using the pressure option with Garment Maker -made cloth? I'm working on sofa cushions (again) and I got some promising results with using pressure option, but only with regular objects. If I try the same with Garment Maker -made cloth, the object deflates - even if I use the cap holes option. Link to comment Share on other sites More sharing options...
proces2 Posted April 20, 2010 Share Posted April 20, 2010 i did use it once, very briefly though. i think the only way i found it would work was if i started with a primitive object - usually just a simple box. if i worked with any mesh where i had to weld it to "seal" it - then it would fail in the same way it is happening for you. Link to comment Share on other sites More sharing options...
wannabeartist Posted April 21, 2010 Author Share Posted April 21, 2010 Hi, I got tired of playing with that for now - apparently it really doesn't work with Garment Maker and at least for this project, Garment Maker wasn't really needed. I was having issued with "pointyness" in the corners of my cushions, but tweaking the initial shape seemed to suffice to fix that. I was also planning to have the entire sofa to be one big simulation, in order to get nice variation with the cushions pressing against each other and the frame, but I couldn't figure out how to instance the cushions with the cloth group definitions, so I just made a simulation of one backrest-seat-pair and copied the resulting mesh. It turned out sufficient for now, but I do want to solve that mystery of the groups in the future! Link to comment Share on other sites More sharing options...
