Dave Buckley Posted April 19, 2010 Share Posted April 19, 2010 not a clue what is happening here? please seeimage attached, it's an editable mesh with an edit poly modifier on top and i'm trying to chamfer an edge i need the edit poly modifer so that i can make the chamfer looked curved, unless i can do this with edit mesh? or any other suggestions, round corners in the a&d is not an option as i need multiple edges on the same object with varying fillets/chamfers Link to comment Share on other sites More sharing options...
Dave Buckley Posted April 19, 2010 Author Share Posted April 19, 2010 i can delete the poly's on the side and then recap it using the border sub-object mode, but every time i chamfer another edge, it does the same thing. Link to comment Share on other sites More sharing options...
DanGrover Posted April 19, 2010 Share Posted April 19, 2010 How about if you weld vertices with a small area before chamfering? Link to comment Share on other sites More sharing options...
Dave Buckley Posted April 19, 2010 Author Share Posted April 19, 2010 i tried that, perhaps i should increse the threshold more. i am doing it another way know, i've remodelled it from splines in max, much easier and quicker than me trying to solve that problem Link to comment Share on other sites More sharing options...
Koper Posted April 19, 2010 Share Posted April 19, 2010 there is no real info between the curve and the outside corner. just cut from one of the vertexes in the curve to the outside top corner and it should be fine Link to comment Share on other sites More sharing options...
Dave Buckley Posted April 19, 2010 Author Share Posted April 19, 2010 cheers koper Link to comment Share on other sites More sharing options...
Claudio Branch Posted April 19, 2010 Share Posted April 19, 2010 If you can't get it to work with welding the verts, then just recreate the section, Extrude, add Edit Poly and use Chamfer for all the edges. Link to comment Share on other sites More sharing options...
Dave Buckley Posted April 19, 2010 Author Share Posted April 19, 2010 Cheers claudio, that's what I did in the end. I'm working with illustrator files which isn't helpin. I've remodelled everything Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted April 19, 2010 Share Posted April 19, 2010 Maybe just try a retriangulate on the sides. Link to comment Share on other sites More sharing options...
DelfoZ Posted April 19, 2010 Share Posted April 19, 2010 some times what i do to fix that kind of issues ( if the profile is a little complex ) ill go to Create > shapes > Section and make a Section from the geometry. if that don´t help then i redreaw the shape .. Link to comment Share on other sites More sharing options...
clauco Posted April 19, 2010 Share Posted April 19, 2010 Hey! Peter is right! Just try conecting the vertex of the concave polygons with the oposite vertex at the top, do that on both concave side polygons of the geometry. The only thing you need is to retriangulate the geometry! But chamfering edges looks better and your problems is solved. Link to comment Share on other sites More sharing options...
