wanted lighting suggestion reqd..
karuna.a
hi friends.. here i have attached my model...
plz suggest me ideal lights (omni, spot).. not vray light (am just started learning)
also how can I create cove light on the top false ceiling...
thanx as advance...
cheers,
Karuna:)
Edited by karuna.a
thanx as advance...
cheers,
Karuna:)
you need to tell us what render engine you're using. but you definitely have to go for photometric lights. there are a lot of tutorials out there.
is going to be slower to put some good scanline settings than learn the basis of Mentalray ( for a learning process i will not buy Vray when you have such an amazing Engine already in max ( Mentalray).
quoted for agreement. the only advantage i can see with vray is the amazing amount of readily available textured models on the net.
hi friend.. where can i get good tutorial for mental ray?
We undertstand you're trying to learn but we can't just how to do it.You would not really learn anything and it would not really be your own. Do some tutorials, there are loads online to help you, Then come back and we can really get in to how to improve your images.
We have all been new to this at some point, but the ground work really is up to the individual.
thanks for ur words..
in this I am running short of time to submit this..
anyway thanx again cheers!!
You can also read up on the 3ds Help file on Radiosity... it would make your scanline images more realistic.
hi Sanchez,
i have tried and got weird result might be I messed up with parameters...
I need to learn that my friend.. thanx for ur suggestion... cheers!!
You can always try YOUTUBE for a fast, free and specific topic
or if u have extra money to spend arround then :
1- LYNDA tutorials http://www.lynda.com/home/ViewCourses.aspx?lpk0=127
Check this 2 chapters or tutorials link or w/e (im pretty sure u can watch some for free )
/ 3ds Max 2010: Lighting and Rendering with mental ray
/ 3ds Max 2010 Textures and Materials
2 Jeff Patton http://www.thegnomonworkshop.com/store/category/205/Jeff-Patton
very cheap price if u askme, everytutorial last 1 hour : check this tutorials ( a must )
/ Architectural Interiors Daylight - 3ds Max Techniques with Jeff Patton
/ Architectural Interiors Night - 3ds Max Techniques with Jeff Patton
/ Architectural Exterior Night - 3ds Max Techniques with Jeff Patton
/ Architectural Exterior Daylight - 3ds Max Techniques with Jeff Patton
Thanx man...
i am not have so much money to spend my friend..:D
