david.s Posted April 22, 2010 Share Posted April 22, 2010 Having tried the Cinema 4D v11.5 demo, my ultimate fantasies for Max include: 1. Being able to continue working on the scene while rendering. Something I had never considered possible before trying C4D! 2. Being able to open more than one max document within the program. That is a real productivity booster! 3. An Interactive Region Render that works with whatever renderer is being used. 4. The ability to scatter MRProxies over meshes or selection sects (without needing an extra plugin). Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted April 22, 2010 Share Posted April 22, 2010 > 1. Being able to continue working on the scene while rendering. I like working on a scene and chucking up a few variations with Maxwell in order to test variations. Work work render work work render work work render. Go watch all three in progress. Link to comment Share on other sites More sharing options...
Lester_Masterson Posted April 22, 2010 Share Posted April 22, 2010 - Actually having "esc" do something when the dialogue box says "Press "esc" to cancel operation" - Have a practical way to eliminate 15 instances of "Metal-Chrome" in a scene. ( Merge several objects with slightly different properties all called "Metal-Chrome" into a scene and you'll see what I mean) - Be able to insert AutoCAD drawings with the blocks "exploded". I know there are several ways around this, but none are elegant - Bring the MS Paperclip on board so he can taunt us when we least need it. "You look like you're trying to perform a complex Boolean operation...Can I corrupt your mesh for you?" / I'm done Link to comment Share on other sites More sharing options...
vizfx Posted April 22, 2010 Share Posted April 22, 2010 How about more CUDA implementations http://www.nvidia.com/object/cuda_home_new.html Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted April 22, 2010 Share Posted April 22, 2010 2. Being able to open more than one max document within the program. That is a real productivity booster! Not exactly what you want, but search for the copy and paste script, and then add it to one of your quad flight outs. This way you can launch a couple of instances of Max, with different models loaded into each, and copy and paste between the two. It is a productivity booster. Link to comment Share on other sites More sharing options...
Chad Warner Posted April 22, 2010 Share Posted April 22, 2010 Not exactly what you want, but search for the copy and paste script, and then add it to one of your quad flight outs. This way you can launch a couple of instances of Max, with different models loaded into each, and copy and paste between the two. It is a productivity booster. I love that script. Link to comment Share on other sites More sharing options...
lee81070 Posted April 22, 2010 Share Posted April 22, 2010 A quick and easy way of locating which texture a missing bitmap is assigned to...especially if the material editor slots are full. Actually, while I'm at it, the ability to have as many material slots as I want, not just 24 Link to comment Share on other sites More sharing options...
jsf Posted April 23, 2010 Share Posted April 23, 2010 A Sweep tool where the mesh doesn't go black when it turns a corner. This would make it usable for things like crown and base moldings, railing caps, door casings, etc. My current work around is to extrude a profile shape and miter every corner, this is time consuming and frustrating knowing that time could be saved with a workable sweep modifier. Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted April 23, 2010 Share Posted April 23, 2010 Does turning off "Smooth Path" solve your problem? Link to comment Share on other sites More sharing options...
jsf Posted April 28, 2010 Share Posted April 28, 2010 Thank you Peter. Yes, unchecking Smooth Path does remove the blackness at the corners. I didn't see your post until today, just ran a quick test and got much more favorable results. Thanks for the tip, this is going to save a lot of modeling time from now on. Link to comment Share on other sites More sharing options...
DanGrover Posted April 28, 2010 Share Posted April 28, 2010 A quick and easy way of locating which texture a missing bitmap is assigned to...especially if the material editor slots are full. Actually, while I'm at it, the ability to have as many material slots as I want, not just 24 2011's Slate material editor will make your wishes and dreams come true! Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted April 28, 2010 Share Posted April 28, 2010 > smooth Yay, I'm glad. I was beginning to wonder if I should follow up with a p.m. because if it worked... Link to comment Share on other sites More sharing options...
TJunkers Posted May 26, 2010 Share Posted May 26, 2010 I love the 2011 Node based Material Editor but I wish there was a small bar (like in Cinema 4d) where it just shows you materials that you can drag and drop into your scene. The material editor now is HUGE!!! Link to comment Share on other sites More sharing options...
