helenistikyay Posted April 22, 2010 Share Posted April 22, 2010 need advice , tell me what do you think about it camera angle, light, environment etc. Link to comment Share on other sites More sharing options...
gwb90 Posted April 22, 2010 Share Posted April 22, 2010 you need give us some more info. what software u using? Link to comment Share on other sites More sharing options...
frank1331 Posted April 22, 2010 Share Posted April 22, 2010 Agreed, there isn't much to go on. But there are quite a few issues you should look at fixing. 1. The building looks like it about to fall over, check your camera. 2. There is just way too much entourage, specifically people going on in the image. It's too busy. 3. Improve the textures that you are using. 4. Shadows need some work as well. Its a good start, but could use some work. Link to comment Share on other sites More sharing options...
roughwetgrass Posted April 22, 2010 Share Posted April 22, 2010 The two things I see are: 1. Lacks depth, needs more/better shading to have it pop out, so to speak. 2. The perspective is off. Make it a two-point perspective - it will be easier to place to entourage...(which there is too much of, as the previous poster mentioned.) Link to comment Share on other sites More sharing options...
