Tommy L Posted April 22, 2010 Share Posted April 22, 2010 Hi guys, does any one know if there is a 'snapshot tool for recording the screen? For instance, is there a screengrab function that will record one frame per minute, but I can also hit a shutter whenever I want? So I could end up with a frame sequence of my workflow but also record vital items that are only onscreen for a couple of seconds. I know its a bit specific, but you never know! Thanks, Tom. Link to comment Share on other sites More sharing options...
Koper Posted April 22, 2010 Share Posted April 22, 2010 hmmm, smart Don't know of any script but will have a quick go at it. Link to comment Share on other sites More sharing options...
Koper Posted April 22, 2010 Share Posted April 22, 2010 ok, so maxscript already has a script that would grab the viewport to save and open the save dialogue. it also automatically sets the name to the max file name and also the location to where the max file is. thats perfect. we can bypass these setting so that it does it automatically. what format do you want? bmp,jpeg,... then we just need to put it in a recurring loop Link to comment Share on other sites More sharing options...
Koper Posted April 22, 2010 Share Posted April 22, 2010 Ok, times up, here is what i came up with. its very very dirty but works for now It requires you to save the max file and then generates the bitmap file from this file name and file location. It saves as jpg in an interval of 60 sec but you can change this in the script on line 11 - local time_interval = 60 -- Set how many seconds to wait here and you can change the file type on line 103 - bmp_name = maxFilePath + mfn +"_" +gvn + "_" + gct + "_" + (c as string) + ".jpg"--build the output file name just close the little popup menu showing the time to close the script if you do this you you'll lose the file name increments but can set again where to start counting on line 12 - local c = 0 -- the file name increments as i said, its a dirty one. If any one feels to put it in a structured menu pls do so, or i'll come back to it later enjoy the script is in the next post Link to comment Share on other sites More sharing options...
Koper Posted April 22, 2010 Share Posted April 22, 2010 rollout viewSave "Viewport Auto Save " ( timer clock "Time" interval:1000 label the_time "1" local a = 0 -- loop counter local time_interval = 60 -- Set how many seconds to wait here local c = 0 -- the file name increments on clock tick do ( a = a + 1 valUp = (the_time.text as integer)+1 the_time.text = valUp as string If a == time_interval then ( a = 0 c = c + 1 Print "viewport saved" ( --------------------------------------------------------------------- --GRABVIEWPORT MACROSCRIPT --Created:3/23/99 --Edited:4/28/99 --by Borislav Petrov --bobo@email.archlab.tuwien.ac.at --------------------------------------------------------------------- --Snapshot Active Viewport to Bitmap --Filename in format: --VPGRAB_MaxFileName_ViewportName_CurentFrame.ImageFormatExtension --------------------------------------------------------------------- -- --Init Variables local grab_bmp --bitmap to put the snapshot into local bmp_name --name of the bitmap to save local get_viewport_name --viewport name local gac,gct,mfn --variables to hold ActiveCamera, CurrentTime, MaxFileName -- --Start Macro grab_bmp = gw.getViewportDib() --get the viewport bitmap into variable get_viewport_name = viewport.GetType() --get viewport name gvn = get_viewport_name as string --convert viewport name to string gvn = substring gvn 6 (gvn.count-5) --cut the string if gvn == "camera" then --if the remaining string is "camera" ( gac = getActiveCamera() --get the camera gvn = gac.name --get the name of the camera ) mfn = MaxFileName --get max file name if mfn == "" then --if there is no name mfn = "Untitled" --use "Untitled" else mfn = getFileNameFile mfn --use the file name without .MAX extension gct = SliderTime as string --get current frame time -- bmp_name = maxFilePath + mfn +"_" +gvn + "_" + gct + "_" + (c as string) + ".jpg"--build the output file name -- --Display file save dialog -- bmp_name = getSaveFileName caption:"Save Viewport to:" filename:bmp_name \ -- types:"BMP(*.bmp)|*.bmp|TIFF(*.tif)|*.tif|JPG(*.jpg)|*.jpg|TGA(*.tga)|*.tga|" -- grab_bmp.filename = bmp_name save grab_bmp -- if bmp_name != undefined then --if user has confirmed / entered a valid name -- ( -- grab_bmp.filename = bmp_name --set output name to the one entered in the save file dialog -- save grab_bmp --save the bitmap -- display grab_bmp --display the bitmap in a VFB -- ) -- )--end of script ) ) ) createDialog viewSave Link to comment Share on other sites More sharing options...
Tommy L Posted April 23, 2010 Author Share Posted April 23, 2010 Wow! Koper, you are the bomb. I will give it a go tomorrow. I was actually looking for a windows one, so whatever I was doing would be logged (as in all programs, especially photoshop) but this is a gem anyhow. It will make interesting viewing as a movie after the project. Link to comment Share on other sites More sharing options...
epelj1 Posted April 23, 2010 Share Posted April 23, 2010 Take a look at a program called FRAPS. I've never used it, but it looks like it might do what you want. I know it's WIDELY used among gamers. Link to comment Share on other sites More sharing options...
Koper Posted April 23, 2010 Share Posted April 23, 2010 oh, right, hehe , screen capture, not viewport grab maybe we can incorporate the prt scr button to be pressed automatically, and then opened and saved by the max frame buffer. hehe, got that one wrong but it still makes for a nice little script Link to comment Share on other sites More sharing options...
Tommy L Posted April 23, 2010 Author Share Posted April 23, 2010 Ill try both. I think Fraps only goes down to 10fps. Still, I think that would be fine. Looks like its also application specific, rather than a screen capture. Both offer more than I was hoping for. Thanks! Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted April 23, 2010 Share Posted April 23, 2010 Snagit is probably the one you want, i know there are a couple opensource/free utilities but i can't recall the names since we got Snagit (from the same folks who did Camtasia) Link to comment Share on other sites More sharing options...
John Dollus Posted April 26, 2010 Share Posted April 26, 2010 http://camstudio.org/ open source screen recording software for capturing both audio and video of what's going on. Generally, I find it best to record the video first and then overdub the audio later to avoid all the little things that usually happen during recording like dogs barking or pizza delivery interruptions etc.. Link to comment Share on other sites More sharing options...
