cmrhm Posted April 23, 2010 Share Posted April 23, 2010 (edited) Hi, guys: I am taking ARE site planning test soon. Here I encountered a question regarding the water drainage issue on a slope. Many of us want to see if I can run a simple simulation to see how the water really drained from higher contour to the lower. Pls see the attached. I don't need to have beautiful rendering but I need the water can come down the hill by gravity. Any quick and accurate way to do it? It seems I need to use particle flow. or some plugings like blender. Any tutorials? Edited April 23, 2010 by cmrhm Link to comment Share on other sites More sharing options...
aaronrumple Posted April 23, 2010 Share Posted April 23, 2010 Hi, guys: I am taking ARE site planning test soon. Here I encountered a question regarding the water drainage issue on a slope. Many of us want to see if I can run a simple simulation to see how the water really drained from higher contour to the lower. Pls see the attached. I don't need to have beautiful rendering but I need the water can come down the hill by gravity. Any quick and accurate way to do it? It seems I need to use particle flow. Any tutorials? Don't need a computer to do this. Water runs 90 degrees to the contours. You can pick an point and draw lines from there to perpendicular to the next lower contour. Repeat until you get to the bottom. That is the path that that drop of watter will take. Link to comment Share on other sites More sharing options...
cmrhm Posted April 23, 2010 Author Share Posted April 23, 2010 Don't need a computer to do this. Water runs 90 degrees to the contours. You can pick an point and draw lines from there to perpendicular to the next lower contour. Repeat until you get to the bottom. That is the path that that drop of watter will take. Aaron: Thanks for reminding me 90 degree rule. Let me think again... Link to comment Share on other sites More sharing options...
