rubynet Posted April 26, 2010 Share Posted April 26, 2010 I'm using MAX 2011+Vray 1.5 sp4, but when I import models from SU, the materials are converted to A&D materials, how can i convert (ont manually) the materials to Vray? the Quad-Menu converter dose not seem to work. thanks Link to comment Share on other sites More sharing options...
Chad Warner Posted April 26, 2010 Share Posted April 26, 2010 You could try the script "Material Converter" here: http://www.motivacg.com/descargas_en.php I've had good luck with it. Link to comment Share on other sites More sharing options...
rubynet Posted April 26, 2010 Author Share Posted April 26, 2010 thank you very much chad, that worked like a charm. Link to comment Share on other sites More sharing options...
braddewald Posted April 26, 2010 Share Posted April 26, 2010 I've been using this as well and, besides setting glossiness values to weird numbers below .5, it works great for me too. My question is why are there two vray options on the second drop-down menu?? Link to comment Share on other sites More sharing options...
Jan Posted April 28, 2010 Share Posted April 28, 2010 My question is why are there two vray options on the second drop-down menu?? Oops, my fault. Vray renderer class name has changed many times, so I must do some "tricks" to know if vray is present (the drop-down only lists installed renderers). Probably some new version has changed (again) his class name and now it returns true in two tests. I'll fix it in next version. Regards Link to comment Share on other sites More sharing options...
