jamesB Posted May 1, 2010 Share Posted May 1, 2010 I can't seem to import FBX or DWG files larger than 10 MB files. When i import or link I just get a blank view as if i haven't imported anything. Smaller files do import though. Could this be a bug? Link to comment Share on other sites More sharing options...
jamesB Posted May 1, 2010 Author Share Posted May 1, 2010 Turning off RPC in the other applications before export seems to solve the problem. Link to comment Share on other sites More sharing options...
gradjinko Posted November 23, 2010 Share Posted November 23, 2010 I have a problem. Using AutoCAD Architecture 2011 and 3ds Max Design 2011, when I want to import dwg file to 3ds max, my whole building is black. He recognizes layers but the whole building completely black. Can anyone help me and tell me what the problem is. Thanks in advance. Link to comment Share on other sites More sharing options...
postite Posted November 25, 2010 Share Posted November 25, 2010 > Marko Perhaps it's a normal problem. You can try to convert the mesh in poly edit, select all poly and use the "turn" function. Link to comment Share on other sites More sharing options...
neil poppleton Posted November 25, 2010 Share Posted November 25, 2010 First thing to check is make sure the Autocad model is near 0,0,0 co-ordinates in world space. Link to comment Share on other sites More sharing options...
Spring1985 Posted December 22, 2011 Share Posted December 22, 2011 (edited) I have a problem. Using AutoCAD Architecture 2011 and 3ds Max Design 2011, when I want to import dwg file to 3ds max, my whole building is black. He recognizes layers but the whole building completely black. Can anyone help me and tell me what the problem is. Thanks in advance. I have the same problem. Can you please tell me how did you solve it? I figured it out For those who are interested in the answer, when you import file, at import option, Geometry choose from the list Layer, Blocks as Node Hierarchy. This is the key. Then another problem I had, the image was deformed with thick lines, the solution is at import options, Spline rendering, Thickness 0,0. Edited December 25, 2011 by Spring1985 Link to comment Share on other sites More sharing options...
