I need Help with grass PLS
Guest stol2004
Guest stol2004
Hi ! Im trying to render with maxwell plugin in rhino and the grass doesnt seem to get any realistic look. I set up the displacement height at 0.5 offset 0.1 and precision at 90 and the results are bad ... I tried a lot of settings and all seems to be bad ... Oh and i get that white area on the right.. I dont know where that result from...Can anyone give me a tip on how to set up the grass ? Thnx very much ( And pard my French ;))
check the links to understand better my problem
http://i293.photobucket.com/albums/mm61/stol2004/album/27.png
http://i293.photobucket.com/albums/mm61/stol2004/album/Untitled.png
http://i293.photobucket.com/albums/mm61/stol2004/c.png
[ATTACH=CONFIG]36928[/ATTACH][ATTACH=CONFIG]36929[/ATTACH]
Edited by stol2004
Guest stol2004
Thank you , but Im using Rhino and maxwell plugin for render ... so the video u showed me doesn't work for me in this case.
  • 6 months later...
