tecton3d Posted May 3, 2010 Share Posted May 3, 2010 I have a very small and simple sample file I created in Revit Architecture 2010 and have linked that file into Max via the file link manager and .fbx format to test this feature. I can render the linked scene just fine without any imported models but when I import>import or import >merge furniture objects into the max file, i get the error below: the file i'm attempting to link is about a 350k poly piece of furniture and no matter what format I import or merge it as, I still get the error which appears to be a memory issue but max is not using all of my available memory and the settings are no where near maxed out on a very small scene. I know this setup is old/minimal but should be adequate: dual opteron with 4gb ram quadro fx3400 any help diagnosing what is happening is greatly appreciated! Link to comment Share on other sites More sharing options...
Macer Posted May 3, 2010 Share Posted May 3, 2010 What happens if you apply a different/default material to the problem object? Can you import the object into a clean scene, do you still get issues with it? Link to comment Share on other sites More sharing options...
tecton3d Posted May 4, 2010 Author Share Posted May 4, 2010 it turned out to be a memory issue so I ran the 3gb switch and it works no matter the configuration of import/merge and/or file types. cheers! Link to comment Share on other sites More sharing options...
