sefianea Posted May 8, 2010 Share Posted May 8, 2010 I am trying to model this scene, and I am having some problem easy and effective way to model the twisted column. Link to comment Share on other sites More sharing options...
DavidR Posted May 8, 2010 Share Posted May 8, 2010 extrude a bunch of instanced cylinders with many segments, add twist modifier for the bottom part. Play with cylinder segments to get desired smoothness. For top part, make shape like pointy flower, extrude, and do same as bottom column. Link to comment Share on other sites More sharing options...
DelfoZ Posted May 8, 2010 Share Posted May 8, 2010 (edited) create the base Shape ( you can make it with a Star, convert to spline, convert the exterior vertex to curves) create a line , go to modify>compund Obj >LOFT > select Shape click the shape ,Then go to modify and twist it. Hope this helps. [ATTACH=CONFIG]36993[/ATTACH] Edited May 8, 2010 by DelfoZ Link to comment Share on other sites More sharing options...
intero_ua Posted May 9, 2010 Share Posted May 9, 2010 sefianea, 3DATS have a tutorial about creating twisted objects, you can check it out at http://www.3dats.com/free/ you can preview that particular tutorial here: http://www.youtube.com/3das3dats#p/c/B69220F158B78D9E/5/PqK19yDA8cs Link to comment Share on other sites More sharing options...
sefianea Posted May 11, 2010 Author Share Posted May 11, 2010 I tried DelfoZ method It worked fine..thank you again guys... Link to comment Share on other sites More sharing options...
