Building a 3D ramp
akinlolugboji
  • 3 months later...
Hi Akinlolugboji,
Not sure if you eventually got a solution to this thread. Anyway, if you are good in max or rhino or some other surface modelling tool, then this can be done in a snap. However attached is a way round it in autocad ( 2011 though). All I did was to draw up a line on Z axis to indicate the gradient in height from lowest to highest.
- Then use SPLINE to draw up both the inner and outer archs.
- Furthermore, conect the height points drawn with lines with the spline as well
- Use the surface network tool in surface creation to create the surface.
- You can then from here offset the surface and do alot other tweaks.
But to be honest, this may take about 10minutes of your preciuos time, so I will suggest do it better in max or rhino.
