YOHKOH Posted May 10, 2010 Share Posted May 10, 2010 Hi I'm applying an extrude mod directly to a spline. Is there a way to control which direction the extrusion happens Ta Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted May 10, 2010 Share Posted May 10, 2010 It will extrude in the Z axis of the grid that it was drawn in.. to "fix" the extrusion if it is going sideways for instance, an easy way is to draw a circle with auto-grid 'on' perpendicular to the direction you wish it would go, attach the problem spline, and delete the circle. otherwise theres something of a extrude along spline function built into edit poly somewhere that may help if that wasn't the problem. Link to comment Share on other sites More sharing options...
LKlemenc Posted May 11, 2010 Share Posted May 11, 2010 You can also rotate or align spline to XY plane (if it was drawn on any other plane) and apply XForm modifier (you can also use ResetXform command from Utilities). Theb you can collapse stack and rotate/align spline to previouse location and extrude. Regards, Luka Link to comment Share on other sites More sharing options...
YOHKOH Posted May 11, 2010 Author Share Posted May 11, 2010 Thanks guys Link to comment Share on other sites More sharing options...
