dreamer86 Posted May 17, 2010 Share Posted May 17, 2010 I have installed autodesk backburner on my workstation and 1 node...started monitor/server/manager on ws and only server on node. From backburner monitor i can see both workstation and render node, but when i click on plugins-3ds max design 2010 renderer plugin i see that only workstation appear. I have installed 3ds max only on workstation, but i have to install it also on node or what? Thanks Link to comment Share on other sites More sharing options...
BrianKitts Posted May 17, 2010 Share Posted May 17, 2010 yes max needs installed on the node as well. you don't need to authenticate the license on the node, just install it so it has the software file to render with Link to comment Share on other sites More sharing options...
dreamer86 Posted May 18, 2010 Author Share Posted May 18, 2010 thanks for reply brian. I tried to intall 3ds max on that node but the installation failed...i opened log file and i see that it's a visual c++ problem. I post the all error : 2010/5/18:11:23:07 USER2 R2 Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=2 2010/5/18:11:25:24 USER2 R2 === Setup ended === I tried to uninstall both visual c++ 2005 and 2008 installed and re-start setup, but it always end like that. Some advices? Link to comment Share on other sites More sharing options...
