multiple objects pointing in the desired way
LuckyST
I'm interested if there's a way to populate a 3d object with other objects, and animate the "children" in a way that they point from their default direction, to a common direction.
such as hair on a person?
[ATTACH=CONFIG]37163[/ATTACH]
thanks, but I want it be possible for multiple objects, that by default
key A) point in different directions.
key B) point in uniform direction (parallel) (in my case upwards).
I see how that could be brute forced with this technique, but I'm hoping for a more elegant solution)
Surely if your look at controller is far enough away the parallel effect could be achieved. The distance may have to be very great but that shouldn't be a problem. You can use scatter with a master object to achieve the "default" mode.
