Fryrender & Rhino mapping
Muz
Hello, hope someone can offer some insight here,
I am enjoying using Fry but am scratching my head over this, I am using Fry in Rhino, and have several mesh items that I am applying a texture to at the layer level, all the meshes are on that layer.
Problem is they are mapped onto some of the meshes horizontally and some vertically.
Some of the meshes are even running in the same direction and are mapping differently.
I can only adjust the coordinates of the texture at the global level in Fry, can't seem to do it at the object level, and not sure if I should need to as I only want the material to go in one direction.
Im using all fry materials and applying them to the layer level
Edited by Muz
Hi Murray. Welcome to CGA. :)
You can apply Texture Mapping to your objects via the Object Properties dialog. It's in the drop down menu for each object. You can apply it to a selection of objects also.
