LuckyST Posted May 20, 2010 Share Posted May 20, 2010 can one attach objects togather and still keep their animation parameters? Link to comment Share on other sites More sharing options...
JonRashid Posted May 20, 2010 Share Posted May 20, 2010 Not as far as I know, Why don't you just create a group Link to comment Share on other sites More sharing options...
BrianKitts Posted May 20, 2010 Share Posted May 20, 2010 Attaching an object will inherit it's parent's animated properties. I'm not a fan of groups as the get messy with layer managment. Depending on your reasoning for the attachment, you might want to just use either a selection set, or place all of those objects on their own layer for easy selection through the layer manager. Link to comment Share on other sites More sharing options...
JonRashid Posted May 20, 2010 Share Posted May 20, 2010 Can you control the pivot point of a selection set? Link to comment Share on other sites More sharing options...
JonRashid Posted May 20, 2010 Share Posted May 20, 2010 haha you just don't like groups I forget sometimes this is cgarchitect and the importance of layers to those who are used to working with them. Link to comment Share on other sites More sharing options...
LuckyST Posted May 20, 2010 Author Share Posted May 20, 2010 I want to apply vray fur to the objects. but I can apply it to only one at a time, and have 100s of copies of same object. if I select both the fur and the object it's applied to, and "instance" it, the fur doesnt get carried to the new item,... and if I "copy" (the fur +object), the fur seems to have trouble remembering it's parameters and screws everthing up. also, I'd like to have only one fur to adjust in case I need to, instead of altering a single parameter to 100s of instances. Link to comment Share on other sites More sharing options...
