Irradiance map error
Devin Johnston
I'm trying to save out my irradiance map using 10 render nodes on a network, I've done this hundreds of times without any problems except for now and I keep getting this "could not save irradiance map" error. The only thing that has changed is I've upgraded to SP5 and I believe that it's causing the problem but I could be wrong. I'm sure that the render nodes as well as the server that they are saving the maps to have full permissions and it's not the hardware causing the problem. The render nodes begin to show this error about half way through the process of rendering out the IR & LC files. I'm at a loss to explain this, has anyone using SP5 tired to render out an IR map over a network?
  • 2 years later...
Hi Devin Johnston,
I actually have the exact same problem as you describe, is there any chance that you solved it? My animation is due for next and I'm completely desperate......
