plastic Posted August 25, 2002 Share Posted August 25, 2002 looking at this images i really wish i had something like this "city engine" for 3ds max: http://www.centralpictures.com/cities/gallery/09_lowspiral.jpg http://www.centralpictures.com/cities/gallery/02_zurich.jpg http://www.centralpictures.com/cities/gallery/08_industrial.jpg http://graphics.ethz.ch/Downloads/Publications/Papers/2001/p_Par01.pdf unfortunately this is a closed system, not even sold as software... i'd like to make a script for max doing something like this (but more simple of course) i'm thinking of an "architectual" version of the great greeble plugin... http://www.asro.kuleuven.ac.be/asro/English/HOME/SBs/3dcourse/gallery/gallery.phtml?var=greeble anyone interested in such a thing, or any ideas how this could work, coding or workflow-wise? Link to comment Share on other sites More sharing options...
Ernest Burden III Posted August 26, 2002 Share Posted August 26, 2002 Originally posted by Marc Lorenz: looking at this images i really wish i had something like this "city engine" for 3ds max: unfortunately this is a closed system, not even sold as software... i'd like to make a script for max doing something like this (but more simple of course) anyone interested in such a thing, or any ideas how this could work, coding or workflow-wise?I didn't read much of the 8 page document, but I did notice that the whole thing is based on an L-system. These are formulas, so why is so 'closed'? I had gotten some freeware L-system software to generate trees and plants, probably as early as 1990, and it still sits on my current hard-drive. What you show is a more advanced application, but perhaps you can contact the researchers for the math. They published this as a paper, after all. Now, there is a poor-man's version of what you saw, if you are happy with a gridded city, or are willing to do some work in Photoshop. I got this idea from another CG artist...perhaps Eric Hanson: The idea is to get a grayscale image to feed into either a heightfield generator or simply to use as a displacement map. You would make it so that black is the lowest elevation, maybe water, maybe street surfaces. One shade lighter becomes sidewalk, for example, depending on the vertical interval. White becomes your tallest point. You can see how this way of working is very easy to do and very logical. You are working in 3D in your mind and 2D in Photoshop. Use a noise generator filter to create a field of squares of various shades of gray. You can do several of these on layers and combine them in various ways, you can modify shapes by selecting areas and doing other filters or fills, raise or lower 'neighborhoods' by lighten or darkening areas. You can add lighter shapes within any building footprint to make setback towers. It's all very logical. You have 256 levels to work in from the lowest to the highest point, so set up a scale in your mind (1 shade = .25 meter, for example, or 1 = one floor) but remember that no detail can be shown below that Z scale factor, so if your scale is 4 meters for a floor-to-floor, don't try to get curbs of .2 meters. When you have a city plan that you like, you can even give it topography. Make a second grayscale image to represent the ground, and use it to 'lighten' the city image. However, note that you must have accounted for the extra shades in your city map. If you will have 20 levels for topography, you will need to subtract that number from your 256 level city map, so the tallest object will be 236. The limit comes from an 8 bit limit on most renderer maps and heightfield generators. Once complete, the map can be used to generate 3D polys in Bryce, for example (note also that Bryce needs a square map--don't ask me why--although you can re-size a rectangular map to a square, and then rescale the model back afterwards) or used as a displacement map. I don't have any software that used displacement, so I haven't tried it myself. I have used the Photoshop grayscale map to generate a terrain in Bryce and it works very well. I tried the same image in Rhino, but did not get results as good as Bryce. Ernest Burden III Link to comment Share on other sites More sharing options...
Ernest Burden III Posted August 26, 2002 Share Posted August 26, 2002 Originally posted by Ernest Burden III: When you have a city plan that you like, you can even give it topography. Make a second grayscale image to represent the ground, and use it to 'lighten' the city image... Ernest Burden IIIActually, there is a minor problem with that step that must be addressed. If you apply a topography slope to the city by lightening the image, you will creat slopes in the buildings, which you don't want. Therefore there would need to be a procedure in Photoshop to lighten the building areas with the AVERAGE of the slope gray under them. I will have to think about the easiest way to do this and report back--if anyone is interested. Ernest Burden III Link to comment Share on other sites More sharing options...
nisus Posted August 28, 2002 Share Posted August 28, 2002 Hi Mark, I've been experimenting on this topic too, although my goal was slightly different... http://nisus.bizhosting.com/nisus_office.html This model was made in less than five minutes by generating geometry due use of a script. Looks like it's useful for generating your cities. (I didn't add a rotation modifier yet, but rotate while moving can generate spirals alike...) rgds nisus ps: tnx for the paper, gonna be my read during supper (I'll keep you informed) [ August 28, 2002, 11:24 AM: Message edited by: nisus ] Link to comment Share on other sites More sharing options...
Ernest Burden III Posted August 28, 2002 Share Posted August 28, 2002 I actually tried what I was writing about, and was not completely happy with the result. As I said, I have used the technique for landforms and it works very well. But wil buildings, it had a tendancy to round the buildings too much. I think the displacement map route will work much better. Ernest Burden III Link to comment Share on other sites More sharing options...
nisus Posted August 28, 2002 Share Posted August 28, 2002 Hi Ernest, Using displacement mapping and the new (free!) symbiont shaders - boxnoise etc - could make your life easier on this, imho check them out (symbiont: last weeks news session) rgds nisus Link to comment Share on other sites More sharing options...
Jeff Mottle Posted August 28, 2002 Share Posted August 28, 2002 Spelling was a bit off for those that were trying the search here is the news item Nisus was referrig to: "Simbiont" http://www.cgarchitect.com/news/default.asp?searchKeyword=Simbiont&Submit=Go&newsSearch=1 Link to comment Share on other sites More sharing options...
quizzy Posted August 29, 2002 Share Posted August 29, 2002 Hey nisus, Its time for you to post that office script, I don't care what you have to do for it; ask your boss, sleep with your boss.... JUST POST IT!!! maybe its a nice start script to begin a paramaetric city script.. Link to comment Share on other sites More sharing options...
stefkeB Posted August 29, 2002 Share Posted August 29, 2002 Originally posted by Marc Lorenz: [...] i'm thinking of an "architectual" version of the great greeble plugin... http://www.asro.kuleuven.ac.be/asro/English/HOME/SBs/3dcourse/gallery/gallery.p html?var=greeble Unfortunately, this page has been deleted on the new version of my page... Those interested in the (simple) greeble results: fun1 fun2 fun3 fun4 Just play with the plugin! Link to comment Share on other sites More sharing options...
plastic Posted August 29, 2002 Author Share Posted August 29, 2002 Ernest Burden III: the edge detection approaches are very interesting, but i will quickly face following limitations when trying to script such a thing: 1. speed limitations with mxs... 2. skill limitations with myself (sometimes i wish that i studied maths/informatic instead of architecture ) maybe i have to give the max sdk another look...c++ shouldn't be that hard, but understanding the sdk is i found following interesting tutorial: http://www.schloerb.com/tutorial/greeblecity_1.htm it would be very easy to pack this into a script, this doesn't exactly look realistic, since its quite impossible to make roofs with greeble (only church-style pyramid roofs), but its a start. Link to comment Share on other sites More sharing options...
Ernest Burden III Posted August 29, 2002 Share Posted August 29, 2002 Originally posted by nisus: Hi Ernest, Using displacement mapping and the new (free!) symbiont shaders - boxnoise etc - could make your life easier on this...As I mentioned, I do not at this time have any 3D software that has displacement mapping, so perhaps you would do me a favor and use this map to displace a surface and show the result. The map is not meant to be a perfect city environment, its just a set of shades for heights with a few roads, a quick Photoshop experiment. Ernest Burden III Link to comment Share on other sites More sharing options...
quizzy Posted August 29, 2002 Share Posted August 29, 2002 here you go ernest..... Link to comment Share on other sites More sharing options...
plastic Posted August 29, 2002 Author Share Posted August 29, 2002 here is my go... rendered with vray displacement & skylight (please ignore the bad-settings-artefacts) Link to comment Share on other sites More sharing options...
nisus Posted August 29, 2002 Share Posted August 29, 2002 hi all, Nice test on Ernests bitmap, I suggest someone use the boxnoise in the simbiont-shaders too... (Srry Jeff... hum hum...!) In the main time I've read the article too: it's great. It reminds me of a book I bought some time ago: Fractal City. Gonna look it up tonight if it got something of use... It's nice that it refers to space syntax too, as I've joined the first space syntax symposium in London (still being an undergraduate at that time) But hell, I don't know any program that can make cities like this yet... It would be extremely useful to have such a plugin... (Maybe Don van add this to worldbuilder? *hint* *hint*) To quizzy... about that box plugin... I'm going to look at it again, because it doesn't work anymore (damn damn, too long ago since I scripted...) As soon as I got it running, I'll post it (I'm my own boss, so I don't have to ask...) because if this can help the community out I'll be glad to help anyone rgds nisus ( Link to comment Share on other sites More sharing options...
Ernest Burden III Posted August 29, 2002 Share Posted August 29, 2002 Originally posted by Marc Lorenz: here is my go...Oh, MAN, that is fantastic! See, that's what I was talking about. Obviously, a better, higher resolution map would yield better results, but the concept works just fine. So displacement mapping is the ticket for poor-mans city backgrounds. Can map-displaced planes be converted to polygon geometry for further editing? Ernest Burden III Link to comment Share on other sites More sharing options...
dwright Posted August 29, 2002 Share Posted August 29, 2002 I know that this is kind of not related but intresting, automatic 3d modeling from video using matchmover and other tools... http://www.esat.kuleuven.ac.be/%7Epollefey/ Link to comment Share on other sites More sharing options...
Jeff Mottle Posted August 29, 2002 Share Posted August 29, 2002 Here's a link to a ton of city building tools, apps etc: http://www.vterrain.org/Culture/BldCity/ Link to comment Share on other sites More sharing options...
plastic Posted August 30, 2002 Author Share Posted August 30, 2002 So displacement mapping is the ticket for poor-mans city backgrounds.well, not exactly. because the poor man can't affort the massive hardware that is needed to render this in reasonable time Can map-displaced planes be converted to polygon geometry for further editing?not with the way i did it. i used renderer-displacement, which is pixel level rather than real faces. (saves a lot of memory, but not render speed) when doing the same with poly-displacement it easily hits 2 million faces and 1GB memory. with face trashing (optimize/multires modifier) the faces can be reduced, but at cost of edges quality. displacement is a very 'unintelligent' brute-force process. thats why i'm not very enthusiastic about it. Link to comment Share on other sites More sharing options...
John Dollus Posted August 30, 2002 Share Posted August 30, 2002 There is a great article in Cinefex on this subject. It is from the Xmen movie article where they talk about the scrolling map of Manhattan that appeared to be made of rectangular pieces of metal. Link to comment Share on other sites More sharing options...
