Time-savers
nisus
Hi all,
Welcome to this new forum! I hope you all enjoy you're stay here ;) Let's take off ;)
We all know that scripts are real time-savers in the production process. What are your favourite kind of scripts? What scripts would you like to be developped?
rgds
nisus
I use the scripts from Blur a lot
http://www.blur.com/blurmaxscripts/
my fav are......
Meshsmooth control
for changing the meshsmooth iterations on multiple objects at the same time
Particle control
since u cant make particles instances, this is handy to change multiple particle values at the same time
Random Select
quick way to select objects randomly
like for instance if u have a lot of trees, use random select and then apply a different colour material to some of the trees...use random select again, and use another different coloured material etc.
Random track timing
to randomize the animation ranges, very cool for lots of the same, i used this to animate hundreds of smurfs running around once :)
Random Transform
select a lot of objects, and random transform will scale rotate or move them by a set amount.
i use that 1 a lot.
Renamer
i hardly ever name things as i go along,
this utility you can rename completely or add prefixes or postfix...very handy if your a lazy namer like me :p
Simple scatter
this 1 is neat, as its really fast to scatter things, and they still stay instances
take a look at the link i posted at the top
these are just a handfull that i use every week,
im sure theres stuff there u will find usefull.
