kid Posted March 13, 2003 Share Posted March 13, 2003 Hi, I'm trying to make a pedestrian ramp which has to rise 3800mm @ 1:14 rise. I got as far as this: The problem I'm having is that the overall length of the ramp is about 55m, and there has to be a landing every 9.5m, how do I make this ramp object have more than one landing? Is it possible, or do I have to stick together 4 or 5 of these single landing ramps at shorter lengths to make up the 55m ramp? Thanks Archicad gurus :angerazz: Link to comment Share on other sites More sharing options...
plastic Posted March 13, 2003 Share Posted March 13, 2003 use the mesh tool for this. it's like the slab tool, but allows you to move each point vertically. it can be controlled in the 3d window. i use it for terrain, variable height walls and ramps. Link to comment Share on other sites More sharing options...
Paul Griger Posted March 13, 2003 Share Posted March 13, 2003 hi kid, i'd either do as plastic says or i may be prone to use a down and dirty method of using a roof object for the ramps and a slab for the landings. stairbuilder has it's limitations is this case, and some others come to think of it best, paul Link to comment Share on other sites More sharing options...
kid Posted March 13, 2003 Author Share Posted March 13, 2003 thanks, I'll give those methods a shot. not much of a stair builder is it Link to comment Share on other sites More sharing options...
Paul Griger Posted March 14, 2003 Share Posted March 14, 2003 Originally posted by kid: thanks, I'll give those methods a shot. not much of a stair builder is it You wouldn't be the first to say so Link to comment Share on other sites More sharing options...
