ArchiCAD > max: Scale Issues
Ken Walton
Any idea why I'm getting totally screwed up scale factors when I bring my models into MAX? I've tried everything I can think of, including exporting a 1:1:1 slab to check my differences. When setting the drawing unit to 1 inch in ArchiCAD, and the same settings in max, my 10' cube is now 3 inches. What am I doing wrong? With other programs (like Rhino), I've been able to jump back and forth (to/from max) seamlessly as long as the units were declared the same in both programs. Any advice is appreciated...
Thanks,
Ken Walton
Damn that's not good. Esp with the old gi problems with size. I;m meant to be introducing viz 4 to arhcitecture students who use archicad, i need this to work please!.
Any help on this? Are you imnporting a 3ds file? Dwg isn't as good at importing the solids for conversion but i think more stable for dimensional correctness. Marc Lorenz is the guy to talk to. He has a nifty clean up tool for archivad models into max/viz too. Anyone know about that?
ok, first get my ArchiCAD Import Wizard script:
http://plugins.marclorenz.com
since i keep getting emails from american archicad/max users i did a tutorial on this topic:
http://plugins.marclorenz.com/archicad_wiz/faq.htm
this should fix it. the problem is that archicad uses metric system units while max/viz uses inch.
please tell me if it works with this settings, i can't really prove it since i work with metric units.
regards, marc
  • 1 year later...
Apart from what Marc allready said (and he can know it) I like to tell you my own settings:
I work in metric all the time. For ArchiCAD to 3ds max exports, I use 1000mm = 1 unit in the ArchiCAD 3ds-exporter. And then I let max rescale (convert units) upon import.
The system units in max can be inch or metric, but the display options are set to metric (that's what I want to see at least). Apparantly, setting the system unit in 3ds max to inch or meters doesn't matter.
I tried a simple slab (10 on 5 meter)
--> When I set the max system unit to inch, the model ends up at 10 on 5 units and when the display unit is meter it's 10 on 5 meters.
--> When I set the max system unit to meters, the model ends up at 393,7 on 196,85. When setting the display unit to meters it's 10 on 5 meters.
By the way, if you know 1 inch equals 2.54cm, then you can understand that 393,7 units = 10 meter / 2.54 * 100
