Tim Nelson Posted October 5, 2003 Share Posted October 5, 2003 Wondering if I could get some help from Vray users out there. Here is my work in progess, which is coming along ok. But what I noticed in this test render is that certain buckets are leaving out part of the images, mostly seems to be where there should be black lines. And then the bucket rendered right next to it is fine. Can anyone offer some suggestions? Heres' the full image And here's the missing pieces Thanks! Link to comment Share on other sites More sharing options...
xgarcia Posted October 5, 2003 Share Posted October 5, 2003 hmmm...are you rendering in bucket mode or single frame? Also try upping your subdivisions (hemisphere) - also check your AA. What settings are you using? Link to comment Share on other sites More sharing options...
Tim Nelson Posted October 5, 2003 Author Share Posted October 5, 2003 rendered in bucket mode at 1600 wide here are some of the settings Link to comment Share on other sites More sharing options...
xgarcia Posted October 5, 2003 Share Posted October 5, 2003 Timm...are the missing lines geometry or bitmap? Try taking Hsph. subdivs to 60 and your secondary subdivisions to 10. See what happens. Also amke sure your bitmaps, if your using them, are set to crop, even if they are not cropped just check it on. Hope that helps. Link to comment Share on other sites More sharing options...
Tim Nelson Posted October 5, 2003 Author Share Posted October 5, 2003 they are geometry. I'll try your suggestions and see if it helps thanks a lot! Link to comment Share on other sites More sharing options...
xgarcia Posted October 5, 2003 Share Posted October 5, 2003 sure - i've found that when I'm missing geometry detail I have to up my GI settings. Subdivisions usually do it. Link to comment Share on other sites More sharing options...
jucaro Posted October 5, 2003 Share Posted October 5, 2003 geometry or bitmap, the culprit when it comes to missing fine details is usually the AA settings. Try rendering in single frame mode using Medium preset and try -3, 2 in your min/max adaptive subdivision settings. -4,4 & using the catmul-rom filter will bring out the details at the cost of higher render times. Link to comment Share on other sites More sharing options...
kid Posted October 6, 2003 Share Posted October 6, 2003 you could try setting your Clr thresh and Nrm thresh lower to say around 0.15 to 0.25 Link to comment Share on other sites More sharing options...
