Vray Displacement Help
aric
Hi Aric
Good post - I´m having the same difficulties myself. The Vray displacement modifier is great(no... it´s fantastic!) - but how to get around the corners with it?!?
Please post your solution when you find it.
Is there any chance that you could post the whole scene that you used to do the picture and a description of you workmethod? I am very interested in seing the map you used in the Vraydisplacement modifier.
Thanks
Ras
The issue is that you have a normal pointing in one direction and a normal pointing in an other, and they are not connected by a smoothing group. I suggest you try to bevel the corner by adding two to three faces, and make sure that the smoothing group goes across (no sharp edged). Then the displacement should work across the surface... at least that is the way to think about it in Renderman and mental ray.
Originally posted by Chad Warner:
Found this from a tutorial somewhere else, but the trick is to apply a meshSmooth modifier to the object, with the default settings, and then use the Vray displacement.
-Chad
yeah, that basically does what Christopher said. All the default normal smoothing of the object goes out the window when the Meshsmooth modifer is applied to it.
Thanks for the info! U guys are better than porn :D . Applied a meshsmooth and everything worked out.
http://www.cgarchitect.com/forum/filepush.asp?file=3_5.jpg
Ras as far as posting the file, i dont know how i can post it here, but i can email u the file and textures if u like. i think u can easily disect the process from looking at the file. but if u prefer i can still explain what i did. its rather elementary my dear watson...
Originally posted by kid:
yeah, that basically does what Christopher said. All the default normal smoothing of the object goes out the window when the Meshsmooth modifer is applied to it. [/QB]
Yeah my response explained why displacment got messed up and how it is related to normals and smoothing, and chads gave a one button solution.
I'm more of a "why then how"... most people just want the "how"... "why" confuses people sometimes.
