Chad Warner Posted September 8, 2003 Share Posted September 8, 2003 Hi all, I have some AEC Windows that I have added muntins to, but the problem is the muntins are on both sides of the glass, and I only want them on the outside face. (for polygon count) Is there any way to do this? Thanks, Chad Link to comment Share on other sites More sharing options...
STRAT Posted September 8, 2003 Share Posted September 8, 2003 whats a muntin? Link to comment Share on other sites More sharing options...
Chad Warner Posted September 8, 2003 Author Share Posted September 8, 2003 I don't remember the technical difference, but a muntin in ADT is the same thing as mullion. (for dividing panes of glass) -Chad Link to comment Share on other sites More sharing options...
STRAT Posted September 8, 2003 Share Posted September 8, 2003 ah. hehe, yup, an americanism. we no call them muntins here Link to comment Share on other sites More sharing options...
Jeff Mottle Posted September 8, 2003 Share Posted September 8, 2003 Mullion: A major structural vertical or horizontal member between window units or sliding glass doors. Muntin: A secondary framing member (horizontal, vertical, or diagonal) to hold the window panes in the sash. This term is often confused with mullion. Link to comment Share on other sites More sharing options...
STRAT Posted September 8, 2003 Share Posted September 8, 2003 in the UK a mullion is the verticle member and a transom is the horizontal member. as for muntins? nobody in my office heard of that word before. Link to comment Share on other sites More sharing options...
Kerry Thompson Posted September 8, 2003 Share Posted September 8, 2003 Hi Jeff is right - Window muntins are secondary framing members that hold multiple panes of glass in a window sash. These are not to be confused with mullions or transoms which relate to the primary window frame members. I suppose the lead in a lead light window could be referred to as a series of muntins. In New Zealand muntins can be referred to as a “glazing bars”. With ADT, muntins are able to be applied to the glass in a window by editing the Display Property of the window style and activating the setting. There is a range of elevation layouts available but no control for the profile or it's position in relation to the glass except centre. Better control of these aspects is achieved by adding a custom block instead. Custom blocks are able to be controlled to be inside, or outside on the glass surface and the profile of the bead can also be defined. Kerry Link to comment Share on other sites More sharing options...
