gable wall
SCOTTH
This is the easy Way!!!
From the Design menu, choose Walls Modify Wall, or on the Walls toolbar, click .
Select the wall, and press ENTER.
In the Wall Modify dialog box, click .
In the Wall Properties dialog box, click the Roof/Floor Line tab.
With Edit Roof Line selected, click Add Gable.
:D
and now for the even simpler way of doing this...
RTFM.... :ebiggrin: ..
Originally posted by STRAT:
i'm still confused.
a gable end is basically a triangle with a thickness. this really is a sintch. how are you coping with the rest of the house if this is the bit which is stumping you?
Wow, way to be helpful Strat. Usually when I don't know the answer I just don't reply. Remember, there was a time when you didn't know anything either, so don't feel like it is too low for you to give a helpful answer, or nothing at all.
Hi Scotth
I extensively use the Wall project method as described by Fernando. I float the roof, in space, over the wall and the project the wall up to the roof – adjust the angle of the roof, re project the wall and it generally works with quite complex roof forms.
You can also edit the wall through a dialogue. Right clicking on the wall and select “properties” Roof/floor line – this will open a dialogue which gives access to parameters which allows editing of roof and floor vertices of the selected wall. Functions like “add gable”, “add step” are available. (I use ADT 4 but similar dialogues are available for ADT3.)
ADT wall gable ends are wall objects and are not made up of combined thickened triangles.
Kerry
yeah, sorry about that orangesad
