maurocan Posted March 9, 2004 Share Posted March 9, 2004 please check these image, i'm having huge problems with lightning (radiosity), any help will be usefull. i'm using 3dmax 5.0 and here are the actual parameters: RADIOSITY PROCESSING PARAMETERS Initial Quality: 85 Refine Iterations (all objects): 3 Refine Iterations (selected Objects): 0 RADIOSITY MESHING PARAMETERS Enabled: yes Meshing size: 0.5m LIGHT PAITING Intensity: 500 lux Pressure: 10% RENDERING PARAMETERS Re use Direct Ilumination fron Radiosity solutuon: NO Render direct ilumination: YES Regather Direct Ilumination: NO EXPOSURE CONTROL Logarithmic Exposure Control: Active LOGARITHMIC EXPOSURE CONTROL PARAMETERS Brightness: 30 Contrast: 50 Mid tones: 1 Physical scael: 1300 THANKS!! Link to comment Share on other sites More sharing options...
cullen Posted March 9, 2004 Share Posted March 9, 2004 con you post a wireframe of where your lights are? Link to comment Share on other sites More sharing options...
kingeldar Posted March 9, 2004 Share Posted March 9, 2004 are they photometric lights? do u use a solar system? are sure of u r drawing scale fitting to max scale? (photometric based on real world scale) cause if drawed in millmeters but max is in meters (it's an example) did u uncheck 'exterior daylight' ? if nothing solves that pb i don't know.... Link to comment Share on other sites More sharing options...
salf Posted March 9, 2004 Share Posted March 9, 2004 Mauro, go to Vrayrender.com and download the free version, it wont have all vray features, but is more than enough. Use vray and you'll forget about radiosity, with incredible results. Link to comment Share on other sites More sharing options...
maurocan Posted March 9, 2004 Author Share Posted March 9, 2004 con you post a wireframe of where your lights are? ill be posting it in a few moments. thanks again. Mauro Link to comment Share on other sites More sharing options...
maurocan Posted March 9, 2004 Author Share Posted March 9, 2004 are they photometric lights? do u use a solar system? are sure of u r drawing scale fitting to max scale? (photometric based on real world scale) cause if drawed in millmeters but max is in meters (it's an example) did u uncheck 'exterior daylight' ? if nothing solves that pb i don't know.... they are not photometric lights... i`m using a sunlight system and some interior lights (spots and omnis) about the scale, as far as i know they match fine ill be posting a wire frame of the position of lights. thanks mauro Link to comment Share on other sites More sharing options...
kingeldar Posted March 9, 2004 Share Posted March 9, 2004 verify u didn't check exterior daylight anyway if u use radiosity it's better using photometric lighjts who are made to run with radiosity and real world scale i don't know much about standard lights so i can't help you Are u sur u unchecked Exterior Daylight attenuation?? lol Link to comment Share on other sites More sharing options...
