Sawyer Posted March 12, 2004 Share Posted March 12, 2004 Fixing this up to be done some day. Love one round at 'em before I sign them as done. As always thanks for the time and thought. Link to comment Share on other sites More sharing options...
STRAT Posted March 12, 2004 Share Posted March 12, 2004 most cool so far. can you fill us in a bit further on the planting bits? Link to comment Share on other sites More sharing options...
Sawyer Posted March 12, 2004 Author Share Posted March 12, 2004 Yeah - All done with max 5 & v-ray. Took a bit over 30 hours modeling and set up. Rendering at 6000 pixel wide and it takes 7-9 hours. The designer did not have a cad drafter so he e-mailed me scans of his pencil sketches which I took into cad and drew the plan and elevations. The building is in Texas and it gets really hot so the main sleeping spaces (the 3 "pods") are more closed off. The curved hall will act as an art gallery. The foreground of one of the picts shows black goo wich is a black swamp. All the picts I saw showed it night black wich I thought was really interesting. I thought I had it done then the designer said he wanted more windows and to changed the color of the wood siding so I am going over it again. Link to comment Share on other sites More sharing options...
Sawyer Posted March 13, 2004 Author Share Posted March 13, 2004 I have been having issue with the materials for the roof. The client wants to see the metal roof rotating in with the curved walls one the curved hallway so it looks like the roof is radiating out from the central point of the curve. I there any way to do this with uvw map or should I just deal with this in photoshop? Thanks Link to comment Share on other sites More sharing options...
Chad Warner Posted March 14, 2004 Share Posted March 14, 2004 I would just polar array some lines in Acad, then eps those out to photoshop, clean up as necessary, then use that as a map. It looks like direction of the seams of the roof in the lower left of the first image are running the wrong way? How did you do the vines on the trellises? (trelli? ) They look really good. Overall, nice images. I definitely get a sense of the heat! -Chad Link to comment Share on other sites More sharing options...
Sawyer Posted March 22, 2004 Author Share Posted March 22, 2004 I would just polar array some lines in Acad, then eps those out to photoshop, clean up as necessary, then use that as a map. -Chad I like that idea I will try it. I ended up creating a new map in Pshop. It looks like direction of the seams of the roof in the lower left of the first image are running the wrong way? How did you do the vines on the trellises? (trelli? ) They look really good. Overall, nice images. I definitely get a sense of the heat! -Chad Yeah I changed the seams for the final. Good point though. The trellis was scatter for the leaves and lofts for the braches. The material is planet. I hadn't used scatter very often & I would do if differently now that I kind of know what I am doing. The trellis file was used as an x-refed scene into the final max file that way I didn't have to regen all those leaves every time. Link to comment Share on other sites More sharing options...
demo38 Posted March 25, 2004 Share Posted March 25, 2004 The reflection seems too blurred in the large window pane, also, if you break up the edge of the rough stone structure to the right, it would set it off. Link to comment Share on other sites More sharing options...
Sawyer Posted September 10, 2004 Author Share Posted September 10, 2004 I made adjustments to this view. I also went from speed tree (original post) to xfrog. I don't remember render times however. Link to comment Share on other sites More sharing options...
Sawyer Posted September 16, 2004 Author Share Posted September 16, 2004 Npr close up Link to comment Share on other sites More sharing options...
STRAT Posted September 16, 2004 Share Posted September 16, 2004 thats a great peice of art m8 Link to comment Share on other sites More sharing options...
Richard McCarthy Posted September 16, 2004 Share Posted September 16, 2004 I am interested in the planting bits too hehe, are those trees from Speedtree...? They look awefully like Speedtree to me... It's really wonderful rendering I really like it... what's your light setting? I have one suggestion though... the roofs, I think you need to add in some details, like fascia and gutters.. they look kinda too simplified... Link to comment Share on other sites More sharing options...
Sawyer Posted September 16, 2004 Author Share Posted September 16, 2004 Thanks Strat made my day. The plants in the first image are speedtree. The update I posted is xfrog. Xfrog is far superior. Link to comment Share on other sites More sharing options...
Eric Posted September 16, 2004 Share Posted September 16, 2004 What about the vines? How did you create those? I don't remember speedtree being able to do anything like that. Link to comment Share on other sites More sharing options...
Sawyer Posted September 16, 2004 Author Share Posted September 16, 2004 I have attached a little diagram showing what I used. The vines are a scatter object if there is any interest I will try to put together a tutorial on how I did it. Most of the growies are just jpgs in photoshop. I am not able to find the link for the free water plants that I used. I wish I has textured them better. Ran out of time. The rest was just me guessing at vray. I had a large output (6000 pixels wide) & I dont remember render times it was around 15 hours. I really wish I could have gotten the times down. Link to comment Share on other sites More sharing options...
