fernando-1 Posted March 15, 2004 Share Posted March 15, 2004 I want to make curtains and bedspreads any tutorials? Thanks Link to comment Share on other sites More sharing options...
Jape Posted March 15, 2004 Share Posted March 15, 2004 Hello jose, If you go to the cgarchitect homepage and then click on ted boardman's monthly columns i think you will find an interesting article about using reactor for fabrics, check the february 2003 column, also i think there was a column (same page) about modeling curtains though im not sure, have a look, there are a lot of good tips there !, Also, though its up to the admins but they probably will say the same, you shouldn't cross-post, posting your question once will almost always lead to smart people helping you out, lots a smart and kind people here ! Jape, Link to comment Share on other sites More sharing options...
DelfoZ Posted March 16, 2004 Share Posted March 16, 2004 Hello jose, If you go to the cgarchitect homepage and then click on ted boardman's monthly columns i think you will find an interesting article about using reactor for fabrics, check the february 2003 column, also i think there was a column (same page) about modeling curtains though im not sure, have a look, there are a lot of good tips there !, Also, though its up to the admins but they probably will say the same, you shouldn't cross-post, posting your question once will almost always lead to smart people helping you out, lots a smart and kind people here ! Jape,http://www.cgarchitect.com/upclose/article10_TB.asp I was looking this page when i read this thread.. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted March 16, 2004 Share Posted March 16, 2004 I would personally go for a modeling approach. You can get great results with a simple plane (editable poly) and the new Shell modifier. Play around with soft selection and you'll see what great results you can get without a cloth simulation (and it's often faster than reactor once you find your way). [] Rick Link to comment Share on other sites More sharing options...
fernando-1 Posted March 16, 2004 Author Share Posted March 16, 2004 Thanks for the comments, Unfortunatelly I have 3dMax 4 where do i get reactor? Link to comment Share on other sites More sharing options...
DelfoZ Posted March 16, 2004 Share Posted March 16, 2004 Thanks for the comments, Unfortunatelly I have 3dMax 4 where do i get reactor?check here. simcloth for max 4. ["SimCloth is a simple cloth plugin for 3dsmax capable of simulating different kinds of fabrics, as well as rigid bodies. SimCloth supports full collision and self-collision detection and response"] http://www.maxplugins.de/max4.php?search=cloth Link to comment Share on other sites More sharing options...
mazearch Posted March 23, 2004 Share Posted March 23, 2004 fernando or someone i am hoping for a little help... i am sure it will be an easy one. i am an old guy learning max as i go teaching a digital architecture class... been a form z vectorworks type of guy for years... so here it is: worked thorugh fernando's cloth tutorial on making a flag attached to a pole... using max 6. i think i am missing a step... make the pole, make the plane... adjust the number of segments... modify it to reactor cloth. make rb collection, make cloth collection... add pole and plane to collections respectively... use mesh select modifier on plane.. select vertex points to attach to rigid body... THEN when i run an animation in reactor, the flag just falls off the gosh darned pole. my TA (member of cg arch) cannot figure out what i did wrong... please help.. would like to show to class. Link to comment Share on other sites More sharing options...
Jason Matthews Posted March 25, 2004 Share Posted March 25, 2004 Maze, try posting a new thread in the max forum, instead of posting om the end of another thread. This will have more opportunity of getting replied to. Jason Link to comment Share on other sites More sharing options...
