M_Jaco Posted March 16, 2004 Share Posted March 16, 2004 Hi all Is there a quick way to attach my lines to the pavement so that the lines should curve the same way as the pavement? The pavement has a lot of lines and is uneven would be very hard to work with each line separately Thanks Link to comment Share on other sites More sharing options...
Wendelld Posted March 17, 2004 Share Posted March 17, 2004 Hi all Is there a quick way to attach my lines to the pavement so that the lines should curve the same way as the pavement? The pavement has a lot of lines and is uneven would be very hard to work with each line separately Thanks Try this link http://www.itoosoft.com/english/freeplugins.html Link to comment Share on other sites More sharing options...
M_Jaco Posted March 17, 2004 Author Share Posted March 17, 2004 Thanks, I'll give it a try Link to comment Share on other sites More sharing options...
Ted Boardman Posted March 19, 2004 Share Posted March 19, 2004 Is there a quick way to attach my lines to the pavement so that the lines should curve the same way as the pavement? The pavement has a lot of lines and is uneven would be very hard to work with each line separately Here's a link to a tutorial I wrote that might help. Good luck Ted http://www.informit.com/articles/article.asp?p=169531 Link to comment Share on other sites More sharing options...
STRAT Posted March 19, 2004 Share Posted March 19, 2004 i normally draw a 3d spline that follows the contour of the terrain, then use max's/viz's SPACING tool to get my line or road markings to follow it. Link to comment Share on other sites More sharing options...
eagle Posted March 19, 2004 Share Posted March 19, 2004 try using compoud/shape merge to merge the line shape onto the pavement, then select the merged faces and detach them. Link to comment Share on other sites More sharing options...
M_Jaco Posted March 28, 2004 Author Share Posted March 28, 2004 Thanks all for replying Wendelld, the glue plug-in did do the job , but adds a lot of vertex to the splines start, your way of doing this is good for a terrain that's curved in only one direction x or y, however if it's curved in both the x and y it will not work (correct me if I'm wrong) eagle,the compound/shape merge is great, but Ted's idea of mapping is good to keep the poly count down Ted, your technique of mapping worked the best for me cuz your avoiding the extra polygons Thanks Link to comment Share on other sites More sharing options...
Ted Boardman Posted March 29, 2004 Share Posted March 29, 2004 >>Ted, your technique of mapping worked the best for me cuz your avoiding the extra polygons Glad to hear that, M_Jaco...extra polygons are your enemy!! Good luck Ted Link to comment Share on other sites More sharing options...
