pwrdesign Posted March 18, 2004 Share Posted March 18, 2004 Hi! I've just started to dig into 3ds Viz that is a pretty new program to me. Im used to Microstation and Lightwave. BUT I've understood that 3ds Viz needs a better render image to produce nice images. I've tryed the Brazil Rio and it works ok, but there are a bunch of render engines out there. So what should I use? I've got some wishes for it: 1. It should work with Autodesk Viz, 3ds Viz R3, 3ds Viz R4. 2. It should handle RPC's. 3. It should handle IES files. 4. It should be able to create nice exterior and interior architectual renderings. Is there a easy way to decide or should I try them all? regards Patrik Link to comment Share on other sites More sharing options...
kingeldar Posted March 18, 2004 Share Posted March 18, 2004 you can produce very nice images with RADIOSITY from VIZ look in the gallery look at fran's posts radiosity is not a bad render all renderer need much work before gettig any good results so tryin all of them is almost impossible cause u need to master a little before having ur own mind about it so u should first stick to radiosty but if u have much time then try VRay and brazil.... good luck Link to comment Share on other sites More sharing options...
mbr Posted March 19, 2004 Share Posted March 19, 2004 You should look at Final Render, too. I am happy with it and the forum has been great help. You can't go wrong with any of them, though, including the radiosity or Mental Ray. Link to comment Share on other sites More sharing options...
pwrdesign Posted March 19, 2004 Author Share Posted March 19, 2004 kingeldar said: you can produce very nice images with RADIOSITY from VIZ look in the gallery look at fran's posts radiosity is not a bad render all renderer need much work before gettig any good results so tryin all of them is almost impossible cause u need to master a little before having ur own mind about it so u should first stick to radiosty but if u have much time then try VRay and brazil.... good luck Ok then, my nxt question: HOW do I use radiosity in Viz?? I cant find any settings that includes radiosity. Atmospheric lightening is that it? I thought that VIZ didnt handle Radiosity, and if I reed the help it says: "3DS VIZ lighting does not calculate the effect of radiosity based on objects in the design. To simulate radiosity, use the Environment dialog to set the color and intensity of ambient light." "Tip: To better simulate radiosity and variations in radiosity due to the varying reflectivity of objects in the design, you can add more lights to a design and set them to exclude the objects you don't want them to affect. You can also set up lights to affect only the ambient component of surfaces. See General Lighting Parameters." So you have to cheat radiosity? Regards Patrik Link to comment Share on other sites More sharing options...
kingeldar Posted March 19, 2004 Share Posted March 19, 2004 i thin radiosity came with viz4 so if u have viz 3 or less u don't have it if u have viz 4then vcheck thos links http://www.cgtechniques.com/tutorials/viz4-radiosity.php http://jan.brookes.com/ http://www.mrussoart.hpg.ig.com.br/more/tutorial/av/introav.htm ( a max one but will fit to viz 4) http://www.jan.brookes.com/tutorials/GI-tut.htmhttp://www.alexcasanova.com/Tutorials/Tutorials.htm http://www.arch.vuw.ac.nz/papers/bbsc303/tutorials/viz/ Link to comment Share on other sites More sharing options...
