cullen Posted March 23, 2004 Share Posted March 23, 2004 I'm in the process of trying to convince the company I work for to get a version of v-ray. I'm currently trying to use the free version until they will purchase the full version. I have finished modeling this but havn't started to fix textures or lighting. I did a check of my railing and this is what I got. I also noticed that there are several other edges that are pretty chagged like this. Does anyone have any ideas? sorry for the size of the pictures but I wanted you to see what the issue was. The first image is with area antialiasing and the second is with video. Though the second looks better, still not the quality I would expect. Thanks for your help.... image 1 image 2 Link to comment Share on other sites More sharing options...
jucaro Posted March 23, 2004 Share Posted March 23, 2004 what are the values of your Vray Image sampler(antialiasing)? It looks lke a fixed sampling rate of 1. Enable adaptive subdivision and use a value of -4, 4 (min rate/ max rate respectively) to achieve best results are you just using the Vray Depth of field/anti-aliasing filter? Link to comment Share on other sites More sharing options...
muzzy Posted March 23, 2004 Share Posted March 23, 2004 What is AA sampling rates ? Try Min 0 Max 2 under Image Sampling. This will add some time though. Try also -1,2 for faster Link to comment Share on other sites More sharing options...
cullen Posted March 23, 2004 Author Share Posted March 23, 2004 Thanks guys, that fixed the problem. I like the result witht he -4,4, but with the time crunch -1,2 is pretty good. Once again, Thanks!!! crw Link to comment Share on other sites More sharing options...
