Photomontage
BeeN
Just about finished this, although materials may still change.
Client took the photo (which is overcast, as always !)
I know the trees are a bit saturated, will sort this out for final image
Modeled in ArchiCAD 8.1 / Rendered Lightscape 3.2
Any comments ?
Nicely done. My comments would be, however......
The whole image is very gloomy. Can't you raise that now that you've matched the lighting of the original photo so well?
Also, the road surface seems to be catching more light than everything else and your glass is a bit lifeless but maybe that's what you meant when you said that materials might change(?)
Nice work. I did notice the trees that were collaged in. A little too bright green for such a gloomy day (the trees to the left look like part of the image). Maybe just lower their saturation a tad.
Very nice, though, and those are just comments after knowing that it was going to be a great image (from the other posts).
Things look pretty well worked in. The brick surfaces of the building look good. A little more 'grunge' on the seawall, especially at the waterline would help it match the foreground.
A little gradient or added to the windows (in Photoshop would be fine) might be a nice finishing touch. In reality we'd more variation than you have and should appear darker down low. The color there is too consistant from top to bottom.
